honda c70 help AGAIN
Pussy Magnet
PostPosted: 13:36 - 05 Nov 2009    Post subject: honda c70 help AGAIN Reply with quote
hi , i have fitted the new pit bike exhaust sounds great but i have no throttle action and it also sounds like its constantly sucking from the airfilter and every now and then it spits a cloud of smoke out of the airfilter. never had this problem before im gussing its down to the fuel and air mixture though any help why its doing this guys ?
cheers
( no spell check using opera )
Cigaro
PostPosted: 16:13 - 05 Nov 2009    Post subject: Reply with quote
Did you upjet the carb? Having a less restrictive exhaust and intake is all very well but unless you've upjetted your bike will now be running seriously lean.
garth
PostPosted: 17:23 - 05 Nov 2009    Post subject: Reply with quote
With standard airbox and pit bike pipe it'll run okay. Mate of mine with a 90 using the same combination held it flat out only stopping for fuel, for 7 hours and it was fine.
Pussy Magnet
PostPosted: 11:46 - 06 Nov 2009    Post subject: Reply with quote
No i dident but i have another mikumi carb ( 26mm ) but i need a new inlet manifold i think and a bigger space ( between the inlet maifold and the carb ) so i cant fit it yet :S but as their the same carb manufactor can i swap the jets over to the c70 carb or could i drill the jets out or do u know where i can get the rite size jet ?
cheers mate Smile
Pussy Magnet
PostPosted: 19:29 - 06 Nov 2009    Post subject: Reply with quote
garth what do u suggest i do to my c70 to make it realy quick acceraltion , i dont care bout top speed to much ?
cheap ways hopefully
garth
PostPosted: 10:30 - 07 Nov 2009    Post subject: Reply with quote
Go one tooth down on the front sprocket. Count the teeth on the one you have already, I may have one you can have for the postage.
The last post was made 16 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.31 - MySQL Queries: 14 - Page Size: 47.54 Kb
