Throttle problem
Gareth
PostPosted: 16:56 - 08 Nov 2009    Post subject: Throttle problem Reply with quote
Hi i have a ns125r 1990 which i am rebuilding as needed a lot of work done. I have fit the the oil and throttle cable, but when i pull the throttle back it wont return. I have tried to adjust the cable and oil pump adjustment but no luck. I think it has something to do with the oil pump but sure, as the cable is not catching at all any help guys will appreiate it thanks Gareth
Blue_SV650S
PostPosted: 18:29 - 08 Nov 2009    Post subject: Reply with quote
Is it the twistgrip snagging on the bar?
Loosen the both cables such that there is some free play and see if it then snaps back.
Then take the oil cable off and see if it snaps back (i.e. it is then just the throttle)
If you close the throttle manually, is does it feel like it is jammed or go back pretty easily??
Gareth
PostPosted: 19:12 - 08 Nov 2009    Post subject: Reply with quote
thanks for the reply, i removed the oil cable but still no good. When the cable but can not see to get any free play on the throttle at all i manually return the throttle it gose back smoothly no problem at all with no jamming. I have tried to loosen the cable but have no free ply at all, Any ideas. Cheers Gareth
Blue_SV650S
PostPosted: 19:17 - 08 Nov 2009    Post subject: Reply with quote
I'd have a look at the slider in the carb, sounds like something might be up with where the cable/nipple goes/seats in there!
TUG
PostPosted: 19:50 - 08 Nov 2009    Post subject: Reply with quote
Slide installed incorrectly?
Haz ER-5, innit!
The last post was made 16 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 2.9 - MySQL Queries: 14 - Page Size: 42.99 Kb
