Reccomend me muff?
PostPosted: 21:53 - 12 Nov 2009    Post subject: Reccomend me muff? Reply with quote
Ok, just bar-muffs as I'm sure you've worked out.
Got the Oxford 'sport' ones and they work ok, but have to be used with some kind of enduro style guard (I made one out of old shelving before).
Any recommendation for better ones? Will be on the zx9 again, as the others are on the KTM and I've found work surprisingly well for off-roading too, so will probably be staying
Ariel Badger
PostPosted: 21:56 - 12 Nov 2009    Post subject: Reply with quote
Blue Peter them.
27cows
PostPosted: 21:57 - 12 Nov 2009    Post subject: Reply with quote
Got some Bike Tec ones. Cheap and cheerful, but do the job.
kate t
PostPosted: 22:00 - 12 Nov 2009    Post subject: Reply with quote
Ha ha, you just made me spit my wine out on the screen, with a laugh reading your post title Surprised Laughing
27cows
Those bucket ones would be the business for keeping the cold out Laughing
Alexio
PostPosted: 22:03 - 12 Nov 2009    Post subject: Reply with quote
Laughing lol, I have to say that this thread also made me laugh very loudly. That poor CG! It looks like a pig and will now be as aerodynamic as one too. Saying that, it is getting rather cold and I need to do SOMETHING to get myself warmer on the roads very soon. Last winter I just struggled through and this winter I'm reading all these posts about the right gear that everyone seems to be posting. I'm hoping that those threads, including this one, shall have me prepared!!! Thumbs Up
kate t
PostPosted: 22:29 - 12 Nov 2009    Post subject: Reply with quote
stop, please. I'll have no wine left Laughing
alexio, loving your avatar in colour! Thumbs Up
Alexio
PostPosted: 22:57 - 12 Nov 2009    Post subject: Reply with quote
Thank you! It ended up taking like, a good hour to figure out how I was going to do it.
As a result of this thread I have been searching around a bit. Does anyone have an opinion on these?
https://www.bitzforbikes.co.uk/-ref-13713-388.html
Pernig
PostPosted: 23:15 - 12 Nov 2009    Post subject: Reply with quote
Having a go at the old vegetable oil bottle hand guards tomorrow. Will let you know if it's any good Thumbs Up.
H100 Breaking for spares
PostPosted: 23:43 - 12 Nov 2009    Post subject: Reply with quote
Unfortunately you really need muffs to be a bit, err, tighter than that Wink... and no, it's not just my small... hands Razz.
Want them to be decently encompassing to get a reasonable amount of stillish air in them.
I have those ones already Alexio - definitely need some kind of solid guard if you want to go over 40mph - otherwise they start to press onto the levers. Not so nice having your brake lever pushed in at 70mph, so having to use your right hand to hold the muff out.
Suspect it's the same with most grips however - as I've said, I made a bodged guard one out of some old metal shelving for current ones.
Be interesting to hear if there's any that 'work out of the box'.
Peirre oBollox
PostPosted: 07:50 - 13 Nov 2009    Post subject: Reply with quote
some kind of metal "bark buster" guard inside the muff would be ideal.
more so something like these https://www.highwaydirtbikes.com/HDB_Shop/index.php?app=ccp0&ns=catshow&ref=handguards minus the plastics
PostPosted: 08:28 - 13 Nov 2009    Post subject: Reply with quote
I have them over the plastic ones on my KTM and it doesn't particulary hinder it. Does perhaps hold it open a bit more, which allows more air in, which may reduce performance, but makes it easier to replace hands. If you're not bodging it, any cheap guard that has two points of contact should do the trick I reckon.
Imonster
PostPosted: 10:57 - 13 Nov 2009    Post subject: Reply with quote
Tucano Urbano one's are excellent - they've thought it through and already put small rubberised holes in the side, so you can slip them over your bar ends to stop them coming back on to your levers. Plus they have additional support towards the front of the muff.
Been running mine for over a year with no issues - arms go deep inside, and they're very warm and waterproof. I wouldn't think twice about buying another pair.
Those who make peaceful revolution impossible will make violent revolution inevitable.
PostPosted: 11:31 - 13 Nov 2009    Post subject: Reply with quote
They look interesting Thumbs Up. Does it have a method to stop the muff pushing downwards at speed?
I found my Oxford ones would still push down onto the lever swivelling around the bar end...
I hadn't got a guard on the clutch side on the zx9, but did have it fastened onto the bar-end (just made a big washer out of some old computer case, then fastened it on with some threaded bar replacing the normal bolt in the bar end.
2E
PostPosted: 12:21 - 13 Nov 2009    Post subject: Reply with quote
I got some bar muffs with a £40 winter gear ebay purchase.
Not exactly sure what make they were as they were completely blank, black with white fur lining but they had a rigid curve on one side which stopped it pressing against the brake/clutch lever at speed... tested to 100mph on a autobahn with no problems!!
I had them fitted to my CB750...
Try to look out for some with that feature on them, it stops you having to fashion something yourself Wink
Bringing Classic Bikes Back Into Fashion
Rides: 1980 Honda CX500
Kris
PostPosted: 12:43 - 13 Nov 2009    Post subject: Reply with quote
https://shop.scootech.co.uk/tucano-urbano-muffs-priced-from-114-p.asp
G, they are great on my Bandit6 (faired).
The rubber grommets fit on the bar-ends *real tight* and they have metal 'L' shaped brackets that fold over and overlap in the middle and are screwed together. They also have plastic inside that stops the levers being pushed back at speed.
I've tested them to 120mph and no pressure on levers at all.
www.prisonplanet.com
Imonster
PostPosted: 14:54 - 13 Nov 2009    Post subject: Reply with quote
+ 1 on my TDM - used to do the whole bodge a washer on thin with other brands, but these are brilliant from the box...
Bikes of Brighton stock 'em - not spam, I have no affiliation with them, just saying if you didn't wanna wait for delivery, etc.
PostPosted: 15:03 - 13 Nov 2009    Post subject: Reply with quote
Cheers, think I'll go for a set then - brighton's a fair way away for me and I'm not in that much of a rush.
Kris
PostPosted: 15:12 - 13 Nov 2009    Post subject: Reply with quote
I got my set from Infinitys in Holborn although you could probably get them cheaper elsewhere.
I was toying with the idea of coming along to the karting / minimoto thingy on Sunday, that way you could 'feel da muff' Razz although the weather is supposed to be a deluge all weekend... Confused
meh
PostPosted: 15:14 - 13 Nov 2009    Post subject: Reply with quote
Can probably get a lift if you come along - definitely from Reading.
Though, reading was named on the news as an area possibly badly hit, so bike may not be the best form of transport, however warm a muff you've got your hands in.
(Though, may still be better than being stuck in a queue in the car Rolling Eyes.)
Imonster
PostPosted: 15:41 - 13 Nov 2009    Post subject: Reply with quote
Didn't realise that they now did different models Doh!
These are the one's that I have - I can't comment on the others...
https://www.harpersraceshop.co.uk/item4085.htm
Edit: Sticking some on the offroader soon too! Gets mighty wet in Sussex in Winter Thumbs Up
PostPosted: 15:55 - 13 Nov 2009    Post subject: Reply with quote
As I've said elsewhere - found that along with the symtec heated grip kit they work really well for greenlaning - out in the ridiculous wet a few weeks ago, while my hands were wet, they stayed warm and it did help dry it out a bit, which made it a lot more comfortable riding generally.
tutton
PostPosted: 17:24 - 13 Nov 2009    Post subject: Reply with quote
Seems most of them boast strengthening to stop it pushing the bar
The motrax description says
Price including VAT - £19.99
Designed to provide optimum protection against the wind and rain
Reinforced leading edge designed to stop wind from forcing muffs onto brake/clutch leversFully adjustable will fit any motorcycle
Heavy duty velcro and adjustable buckle fittings
Reflective leading edges for increased visibility
Will not impede controls or comfort.
https://www.motrax.eu/item3580.htm
Suspect ill buy them, unless the other ones in this thread are a similar price..
instigator
Brick Wall
Peirre oBollox
PostPosted: 17:31 - 13 Nov 2009    Post subject: Reply with quote
G wrote:
the symtec heated grip kit.
got them on mine
Though i did get a mate to ship them from the states
The last post was made 16 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.35 - MySQL Queries: 16 - Page Size: 134.57 Kb
