| _sm |
 _sm L Plate Warrior
 Posted: 18:29 - 23 Nov 2009 Post subject: Aprilia SR 125 Electrical Problems |
Hi all.
I recently bought a 2001 Aprilia SR 125 Max Biaggi Race Rep' for getting about on during the winter.
I'll firstly state that the scooter, to the best of my knowledge, is mechanically sound and runs perfectly fine once started.
Now onto the bad news.
About 2 weeks ago I could no longer start the scooter via the electric starter button, but it would start via the kickstarter fine. I thought this may have been due to a dead/faulty battery but found it strange that the lights and horn etc still worked even when the scooter wasn't running. Up until 2 days ago everything but the electric start was working perfectly until I noticed that my turn signals were no longer flashing. Upon further investigation I found the horn was no longer sounding properly (and sometimes not at all). In regards to the turn signals, while the scooter is idleing, they flash faster than normal, but as soon as the scoot is revved they light up solid and stay solid until turned off or the scoot is brought back to idle. The lights will now no longer work unless the scoot is running.
So this morning I got myself over the garage and got my multimeter out, figuring the battery must have died. Put the multimeter on the battery only to find that it was still showing 12v or thereabouts, this is the same whether the scoot is running or not. The voltage drops when the horn, lights or turn signals are attempted to be operated while the bike isnt running but they do not function at all. The same is true when the scoot is running however the lights function properly and the indicators operate as described previously.
I am at a loss as to what may be wrong, as the battery seems to be holding and getting a charge?
Any help greatly appreciated.
sm |
| finpos |
 finpos World Chat Champion
| _sm |
 _sm L Plate Warrior
| finpos |
 Posted: 19:36 - 23 Nov 2009 Post subject: |
The quick test is to measure the battery voltage with the engine on and the engine off, should be approx 12V (engine off) and then 14V (on, 5000rpm), however if you have a duff battery it'll trick you into thinking it's not working right, so you must always test with a known, good battery.
You seem to be getting some extra power from somewhere with the engine running, which suggests the regulator is ok.
Next step is to borrow any good battery to test with (car battery and jump leads is fine, but disconnect the suspect one), or charge the battery you have overnight, it may last a few minutes, or it may not.
f.
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 19:42 - 23 Nov 2009 Post subject: |
i would just charge the batter for now, as that has been holding charge, but your alternator isn't charging it,
the battery had enough life to make it spark and what not, but not enough to crank over the starter,
first thing i would look at is the main fuse,
and then all the connectors between the alternator and the battery,
then find out if your alternator is ok, then look at the reg/rec
there is a wiring diagram in the wiring diagram thread  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| _sm |
 _sm L Plate Warrior
| finpos |
| _sm |
 _sm L Plate Warrior
| finpos |
| _sm |
 _sm L Plate Warrior
| _sm |
 _sm L Plate Warrior
 Posted: 14:58 - 03 Dec 2009 Post subject: |
Thanks for the info' Colin.
So here's where I'm at currently:
I borrowed an Optimate. This Optimate has 4 lights next to 4 small icons - The 1st icon, a full battery with a , 2nd icon a half filled battery, 3rd icon a very low battery and the 4th a nearly empty battery with a . So I hooked it up to the battery and it displayed a light next to the 2nd icon which I was told is normal. Left it on for 6+ hours and came back to check. The light was now next to the 4th icon. Which I was told means the battery is as good as dead.
Readings with a multimeter are as follows:
Battery with engine off: 12.2v
While on the Optimate: 13.9v
When I attempt to start the scoot via electric start: 2v (it then jumps back up to around 11.7v then builds back up to 12.2v)
(Engine off) When I turn lights on: 0.3v (it then jumps back up to around 11.7v then builds back up to 12.2v)
(Engine off) Indicators flash fine at 11.6v
Once I get the engine running things are confusing and will result in either of the below:
(Engine on) Idle at 9.5v
(Engine revving) 6.5v
With lights on they flicker at idle but dim on revving.
Indicators flash fast at idle but stay solid when revving.
Horn is weak at idle but none existent when revving.
OR
Idles at 12-13v and rises when revved.
Horn works fine, lights work fine and brighten when revving, indicators work fine.
I also notice this change when I am out riding, my lights, indi's etc will all be working fine, then all of a sudden I notice my dash light will dim and my indi's no longer function properly and lights dim when revved.
Hope this can shed light as to what may be causing the problem. |
| finpos |
The last post was made 16 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
