Suzuki Bandit speedometer problem
Dazbo666
PostPosted: 12:38 - 17 Dec 2009    Post subject: Suzuki Bandit speedometer problem Reply with quote
Just a query about the speedo on my 2003 GSF600N...
In the absence of a Haynes manual, I'm having some intermittant fault with the speedo. Sometimes it doesn't work at all, then suddenly starts working part way thru a ride.
Is the speedo/trip comp an electrical connection on the Bandit, or an actual rotating inner cable (as on my previous bike, a GPZ500) ??
Any advice would be helpful because I'd prefer not to start investigating without the help of MrHaynes Thumbs Up
Word of the day : DILLIGAF
Vinyardo
PostPosted: 18:00 - 17 Dec 2009    Post subject: Reply with quote
If it's the same as a '99 Bandit, it's a rotating cable. Could be just the mechanism sticking intermittently - that is what happened to mine
HTH Thumbs Up
--| Current bike: |--
--| Previous bikes: Honda CB500 -- KTM Duke 390 -- Honda CBR1000RR7 Fireblade -- Honda CBR600 FX -- Suzuki Bandit 600 -- Yamaha TTR250 -- Suzuki GN125 |--
Dazbo666
PostPosted: 19:47 - 18 Dec 2009    Post subject: Reply with quote
Will be trying to get a Haynes manual to double check the setup, but it seems like it's likely to be a problem with the cable and/or mechanism. (I'm hoping it's just a matter of a little lubrication in the right place).
Thanks for the info Vinyardo Thumbs Up
temeluchus
PostPosted: 20:20 - 18 Dec 2009    Post subject: Reply with quote
if its a cable it will be blindingly obvious-look at your front wheel and look for the cable, will take u two seconds.
Bezzer
PostPosted: 23:10 - 18 Dec 2009    Post subject: Reply with quote
It's not a cable on the Gen2 600 and 1200s they're electronic driven from a sensor/pick up on the front sprocket. That end doesn't usually cause problems but you can clean it up just to make sure it's isn't the build up of gunge you usually get in that area. Could be a loose/dirty connector at the intrument end, worth going through the connectors to check and clean them up with contact cleaner. Another common problem on Bandits are the wires that wrap round the headstock chafing/breaking that can give intermittent problems until they actually break and cause a permanent problem, check the wiring when you check/clean the connectors there as the speedo wire is one of them.
The last post was made 16 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 45.1 Kb
