Mutiple split link usage YAY or NAY
cyberglass
PostPosted: 15:20 - 07 Oct 2010    Post subject: Mutiple split link usage YAY or NAY Reply with quote
Tried to put my off road wheels on the drz but unfortunately the chains about 4-5 links to short and the off road chain didnt come with it and its a 90 mile treck to go get it.
So if i were to make up a extention piece of chain and use split links (wired to secure) to sue when ive got the off roaders on it will i run into any problems ?
Thanks
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
PostPosted: 15:33 - 07 Oct 2010    Post subject: Reply with quote
I have reused them but I would rather not.
DrDonnyBrago
PostPosted: 15:35 - 07 Oct 2010    Post subject: Reply with quote
You could join a short length of another new chain using two split links, it would be just as safe as using a chain with one split link. The problem is what chain you will borrow a few links from, it would need to be the same as the chain you want to fit and preferably had the same amount of use (i.e. none).
If you meant fit multiple split links in a line to elongate the chain then it wouldn't work because chains are made of two types of links, the master link (i.e your split link) is a version of just one of them.
PostPosted: 16:02 - 07 Oct 2010    Post subject: Re: Mutiple split link usage YAY or NAY Reply with quote
I have done in the past and it's been fine.
The chain on my CRM at one point was made from three other chains - though that was rivet links.
PostPosted: 16:16 - 07 Oct 2010    Post subject: Reply with quote
I won't touch a split link with the smelly end of a shitty stick these days.
That said. A mate of mine used to use two split links on his Nitrous injected TL1000R drag bike. He had the worlds longest wheel adjusters on his stretched swingarm. He'd ride to the track, split the chain, wind the wheel back another 6 inches then add an extra bit of chain using two split links.
The last post was made 15 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 14 - Page Size: 48.28 Kb
