| G |
 G The Voice of Reason
| stinkwheel |
 Posted: 21:45 - 26 Jan 2010 Post subject: |
You could always try whipping out the glow plugs/injector nozzles and seeing if you spray diesel all over the inside of the bonnet when you turn the key.
EDIT: Thinking out loud. What about pushing it backwards while in gear? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| Raffles |
 Raffles World Chat Champion
| G |
| Raffles |
| finpos |
 finpos World Chat Champion
| G |
| reggie |
 reggie Spanner Monkey
| stinkwheel |
| G |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 18:16 - 27 Jan 2010 Post subject: |
Er, isn't it just the battery is fecked (some collapse (knacker completely) when you try and recharge after being sulfated)???
Have you tried jump starting it off another car/van? ____________________ The purpose of life is to fight maturity. |
| G |
| Danny |
 Danny Ask Me About Stoppie School
| Blue_SV650S |
| finpos |
 Posted: 21:56 - 27 Jan 2010 Post subject: |
Almost certainly burnt contacts in the solenoid then, caused by it arcing. Take starter off engine (watch out for any "funny looking" bolts, one is often different from the others), cover hands in elastoplasts, take solenoid off starter motor, dis-assemble solenoid, find blackened contact surfaces on end of plunger, clean, re-assemble in proper order
May want to put 12V directly on the starter with a jump lead to check first, it's a pain to do.
f.
| WildGoose |
 WildGoose White Van Man
 Posted: 21:58 - 27 Jan 2010 Post subject: |
Take it to the scrappy, and get a better van. I hate LT's there is no room to do bugger all under the bonnet.
Back on topic..
Random and un-ordered thoughts....
Is it common rail? (Just curious)
Is there a good battery on there now then?
It should bump start regardless of battery condition or starter.. when was the last time it was running? Did it start ok then?
Have you ever bumped it before succesfully? I don't often bump anything in 5th.
Is it possible to crack the nut on the fuel line at the injector to see if fuel is getting through, or are they all a bitch to get at?
The starter isn't going to do a damn thing with 0.8v.
As for the electrical issue, it sounds like earth or just generally connectivity issue. Checked the engine to chassis earth straps?
But it should go with a bump regardless of all this (as long as you have a bit of juice for the glow plugs, injectors (if they are electronic) etc, so that is more concerning.
What time do you finish work? I could pop round on way home, to hit things and offer swear words. I have jump leads and two reasonable batteries in the back of the van  ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| G |
 Posted: 22:39 - 27 Jan 2010 Post subject: |
| Blue_SV650S wrote: |
One way to find out, short the terminals out, bypassing the relay  |
Good call, should have thought of that, though as goose suggests it's all rather hidden and didn't want to get a shock from the chunky starter wire.
Have to jack the van up, get underneath and reach up between 'stuff' around the engine.
finpos: has been hard enough finding and poking the starter motor stuff with a multimeter - I'll probably see if I can find a mobile mechanic to do it or something.
Goose:
Yes, it is common rail.
I'm confident the battery is good and have tried jumping it from the M3, which has a two month old battery.
It started about half an hour before I failed to start it I think. Must have used the last bit of power at that point as it was fairly low battery. I was just doing it in fifth to see if it will turn over at all, not trying to bump, hard . Very limited space in the car park we are on.
Note glow plug heaters don't work, but no big issue normally, may not help for bumping. Hard to tell if it was turning over or not with the bump.
I don't think I have bumped it properly before without using the starter at the same time.
Haven't checked the engine to chassis earth straps. There was some issues with getting a decent place to put the negative lead of the multimeter on, but think that was more due to general crud over it.
Work can be flexible for me - van is currently at Danny's near the Hospital. |
| Stelmer |
 Stelmer World Chat Champion
| G |
| G |
| Stelmer |
 Posted: 17:49 - 28 Jan 2010 Post subject: |
Startermotors are earthed through the engine.
Sounds like the 2 copper contacts inside the solenoid are worn. They are replaceable if you want a cheap fix, or you can replace the whole unit.
https://www.youtube.com/watch?v=CxjPpytfnv0
Startermotors explained. |
| finpos |
| G |
| finpos |
The last post was made 16 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
