1991 GPZ500S Camchain Tensioner Removal?
MikeyBrown
PostPosted: 20:53 - 13 May 2011    Post subject: 1991 GPZ500S Camchain Tensioner Removal? Reply with quote
Hi,
I'm not sure if this has already been posted somewhere on the forum, and my internet is horrendous on an Ipad, but I would just like to know how I'd go about removing the camchain tensioner from my GPZ500? Is it as simple as just undoing the bolts and removing it from the engine or is more complicated than that?
I am currently waiting for a Haynes manual thats taken over a week to deliver Evil or Very Mad but I just need to remove the tensioner so I can take it to a local shop to order a new one (the shop owner says he needs to see it, to check if he has any decent priced New-Old-Stock in his storeroom). Also, is it possible to rebuild/service the damaged tensioner or is replacement the best/cheapest option?
Thanks in advance
Mike
Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
Current Bike: '07 FZ1N
Trackdays: Darley Moor - 15/6/12, Donington - 28/8/12
PostPosted: 21:11 - 13 May 2011    Post subject: Reply with quote
Yes you can just remove it like that, although make VERY certain you do not crank the engine with it out. Probably best to set the engine to tdc.
However you can't just lob it back in. It is a sprung ratchet, so when you remove it the spring will extend pusher the tensioner out to its full extent. And the ratchet will stop you pushing it back in. Normally remove the bolt from the end, remove the spring, reset the tensioner and put it in place, then replace the spring and bolt (and turn the engine over a few times by hand ).
There is not really that much to wear in one. The tensioner teeth shouldn't move enough to wear while the spring is only there to move the tensioner once in a blue moon to take up slack.
MikeyBrown
PostPosted: 21:30 - 13 May 2011    Post subject: Reply with quote
Thanks yet again Keith Thumbs Up :L I wont be putting it back in until I have the Haynes manual, I just want to get the new part.
If they don't wear that often, what could be causing a rattle/click at idle? At idle, it rattle/clicks and my uncle reckons it's the CCT. When you rev the bike, under load or not, the click disappears at around 3000 rpm :S
PostPosted: 21:52 - 13 May 2011    Post subject: Reply with quote
The cam chains do wear and as they wear the tensioner needs to take up that slack. Just that they seem to get worse at it with age. Possibly the spring getting old combined with it having further to move to take up the tension.
Also on the GPZ there is a primary drive chain taking drive from the crank to the clutch. This can also wear with age but has no tensioner. And can thus slap around like a worn cam chain.
MikeyBrown
PostPosted: 22:05 - 13 May 2011    Post subject: Reply with quote
I'm a little confused as to what I should do. What would you advise? Adjust the tensioner, replace the tensioner, replace the primary drive chain, replace the cam chain or just leave everything and see if it gets any worse or...?
I do appreciate your time to answer my rambling questions by the way so thanks Smile
Mike
PostPosted: 22:26 - 13 May 2011    Post subject: Reply with quote
How long is a piece of string?
They were well known for needing new cam chains years ago.These days people just seem to replace the tensioner rather than the cam chain.
The cam chain is possible to replace with the engine in the frame (use a rivet link one), but the I think the primary drive chain would need a full engine strip.
Personally, they are fairly rattly engines anyway. I would just leave it unless really noisy.
MikeyBrown
PostPosted: 22:42 - 13 May 2011    Post subject: Reply with quote
Hmmmmmm :/ I might just leave it for a few miles on the road and see if it gets any louder/worse. If it doesn't, then I shall just leave it I think. If it aint broke (or obviously broken in this case Wink) then dont fix it I suppose :L might price up some of those parts though, just to get an idea in case I do need to replace one (probably in a couple of hundred miles - its only done 17.8k miles now)
dextersaurus
PostPosted: 01:07 - 14 May 2011    Post subject: Reply with quote
As above.
My GPZ was noisy as hell, tensioner out and clean it up, make sure it'll click out to take up slack, but won't push back. Can also slacken the bolts and let it click out once or twice and put it back in, if you think it's still too slack... wouldn't recommend that though.
Synchronising the carbs can also help a lot. they tend to get a lot noisier when they are out of sync by a tiny bit.
Another thing it could be is the valve clearances... how many miles has it done?
Dunc
temeluchus
PostPosted: 01:58 - 14 May 2011    Post subject: Reply with quote
Kawasaki did change the design of their tensioners through the 90s (I think there was a recall on the zzr1100 for it).
The one on my gpz750r was ditched for a manual one.
Dazbo666
PostPosted: 07:43 - 14 May 2011    Post subject: Reply with quote
@ the OP
Yes you can just take the tensioner out, but as already mentioned, do not crank the engine with it removed.
You'll need a little manual dexterity and the correct procedure to reinstall the new one, but it's more than possible as minor a DIY job
The bike would benefit from balancing the carbs, but also be aware that GPZ engines tend to sound quite rattly compared to a lot of other bikes
(I had a '91 GPZ previously and learned loads about riding and maintenance with that bike Thumbs Up )
Word of the day : DILLIGAF
MikeyBrown
PostPosted: 12:20 - 14 May 2011    Post subject: Reply with quote
Hi,
Thanks for the responses, I'll have a check over the carbs and maybe see about balancing them and to be honest, I might remove the tensioner and just have a poke around with it, see if I can adjust it and check it all over.
And it's done 17600 miles, but it's been, by the looks of it, dry stored for the last 12-18 months. I have serviced it recently (but not valve clearances or camchain tension) and checked everything over to make sure it's roadworthy of course
Failing that, could it just be a typical noisy engine then? I've heard a few people say they sound they're going to explode on idle ahaha other than this rattle/jingle/click, the engine sounds pretty sweet given that it's 20 this year! Wink
The last post was made 15 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 14 - Page Size: 76.14 Kb
