SV 650S 2000 GEARING - Chain & Sprokets
shredtheibane...
PostPosted: 00:10 - 25 Apr 2010    Post subject: SV 650S 2000 GEARING - Chain & Sprokets Reply with quote
Hey Guys && Girls!
First of all, I'm posting this to help out a friend
Okay..
Right i currently have a 650S 2000 Model SV and at the moment is in need of a new chain and sproket kit.
Now i am confident i will be getting a DID X-RING type chain but am in need of some advice.
Currently my rear sproket has 46 teeth and am unfortuantly unsure of the front (need to check.. too late) but am in the position where at 70MPH i'm cruising in 6th @ around 4900 - 5200RPM (kinda feels like i need a 7th gear). The bike also pulls really hard in the higher gears (1st, 2nd, 3rd) and continues to pull hard in the lower 4th, 5th and 6th (eg: pulls to 9500RPM in 6th @ 135MPH (.........Santa pod... ).
My aim is to gear the bike for better/higher top end. I've referred to https://forums.sv650.org/showthread.p...light=sprokets and am guessing mine is probably set at 46 rear 14 front.
Would i be right in saying if i set the rear at 46 and change the front to 15 i would sacrifice a wee bit of acceleration for a wee bit more top end?!?
(Please correct if i'm wrong...)
Finally!
Where is the best and 'cheapest' place to get both the chain (like mentioned DID X-RING) and sprokets?
Thanks again.
Regards,
Ryan
el_oso
PostPosted: 09:55 - 25 Apr 2010    Post subject: Reply with quote
you are correct there about top speed going up and acceleration going down in general. however if you gear it too high, the bike may not have enough power to reach theoretical top speed.
+1 on the front is = to about +3 teeth on the back so you should see quite noticeable change.
just make sure your new chain will fit as the length may need to be altered as it is a bigger sprocket
Duke 390
Car: Jeep Wrangler 4.0L
Blue_SV650S
PostPosted: 19:29 - 25 Apr 2010    Post subject: Reply with quote
I think you have 15F 46R.
The stock gearing is 15F 44R(Faired) 45R(nekkid)
I used to have 14F 45R and it was too 'buzzy' at motorway speeds.
The 15F 44R is Ok, but if you want a large change from what you have now, you need to go 15F 42R or something like that!!! Thumbs Up
The last post was made 15 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.95 - MySQL Queries: 14 - Page Size: 36.52 Kb
