cornering technique
Bubbs
PostPosted: 08:24 - 25 Apr 2010    Post subject: cornering technique Reply with quote
Hi all,
I was hoping you guys/girls could post up some technique that you use when cornering. I don't yet have the confidence to get the bike banked over in a turn as much as i'd like. I'm using the counter steer technique consciously while entering the bend but still almost run wide, or not bank enough. Don't know what the bike will allow me to do really, which i feel is taking the potential fun out of my riding experience.
All/any suggestions are welcome?
Thank you in advance.
Gazdaman
I did a trackday!!!
PostPosted: 08:30 - 25 Apr 2010    Post subject: Reply with quote
Just lean more.
Ride more, lean more, go faster, you'll really surprise yourself how far over you can go. But get faster and lean more GRADUALLY.
If you decide to barrel into a corner 20mph faster than usual, you'll crash.
From looking at your sig you're a fairly new rider, so it's all about practise, and learning how far you can take it. For a bench mark, on most bikes you can get the pegs to touch the floor in a corner.
And also make sure you're looking down the road at the exit of the corner, if you're concentrating on the corner too much, you'll get target fixation and find yourself in the hedge. Look through the corner and out the other side, and you'll find yourself round and out before you know it.
When you have a bit more experience a trackday would possibly help, then you can really test what the bike can do, in some safer circumstances. And once you've got your knees down, you know what you can throw at the bike.
Gaz
Bambam3
PostPosted: 09:09 - 25 Apr 2010    Post subject: Reply with quote
Heh, I have the same fear/problem.
Very new rider myself, only on a L-plated 125, but man it feels scary leaning around corners, to the point I initialy just slowed right down and crawled around alot of them.
Bastard in a car honking behind me earlier while I was out having a practice through some quiet twisty lanes, tight corner going downhill, made me feel a right twat, but any faster I thought I'd come off.
Spent an hour or so going through lanes anyway, just seeing what works and what doesn't leaning/turning wise and it helped alot.
Once or twice I ventured over the line by not leaning enough outta fear, but overall it helped me gain a little more confidence in the bike.
Gazdaman
I did a trackday!!!
PostPosted: 09:10 - 25 Apr 2010    Post subject: Reply with quote
Might be worth checking tyre pressures. They can make a bike feel really strange!
Gaz
iooi
PostPosted: 09:31 - 25 Apr 2010    Post subject: Re: cornering technique Reply with quote
Bubbs wrote:
Hi all,
I I'm using the counter steer technique consciously while entering the bend but still almost run wideAll/any suggestions are welcome?
Stop thinking about it.
Its a natural part of riding and if you are thinking about counter steering, then you are not concentrating enough on riding round the bends.
You should only have to force counter steering if you have gone in way to fast and need to lean a lot more.
Relax, just let it happen Thumbs Up Try to force it and as has been said you will end up shinny side down Crying or Very sad
Bubbs
PostPosted: 09:43 - 25 Apr 2010    Post subject: Re: cornering technique Reply with quote
iooi wrote:
Bubbs wrote:
Hi all,
Nah I'm not forcing it, i'm just concious of it so that it allows me to bank more. On my 125 I had the pegs touching on most of the sharper corners, just don't feel as safe on the SV yet. I guess it's down to practise. Just thought there would be some techniques that could help me along.
Rob W
PostPosted: 10:06 - 25 Apr 2010    Post subject: Reply with quote
As others have said, dont think about it too much, and just LOOK exactly where you want to be going. Surprising how just making sure that you're looking properly at the exit of a corner or wherever you want to be will naturally just make you go there.
Rowey
PostPosted: 10:30 - 25 Apr 2010    Post subject: Reply with quote
Check your tire pressures are ok. Make sure the tires are nicely warmed up. Then find a big, nicely surfaced, quiet roundabout.
Keep a constant speed at medium revs and keep going around in circles (not ovals). Gradually increase the speed by a few mph each time banking the bike over further and further. Moving your arse back in the seat, moving a bum cheek off the inside of the bike and having your head 'kissing' the inside mirror will also help.
It might be an idea to stop every now and again to have a look at your chicken strips to get an idea of how far you're leaning.
ZX6R C6F.
PostPosted: 10:37 - 25 Apr 2010    Post subject: Reply with quote
Thumbs Up exactly how i learnt, except I used a large roundabout in the middle of nowhere at 3 in the morning as i can go both ways round it without much fear Laughing
Ichy
PostPosted: 11:02 - 25 Apr 2010    Post subject: Reply with quote
Make sure your arms are nice and loose with bent elbows, not all tensed up and straight. Try clamping the tank with your legs. Don't try moving all over the bike until your confident with your bum planted in the seat.
Your bike is way better than you, let it do what it does best.
bacon
PostPosted: 11:12 - 25 Apr 2010    Post subject: Reply with quote
Go and download Keith code "Twist of the wrist 2"
I need to watch it again, its very good, and has some great cheesy story line to go with it!
Also you will prob find your road positon will have a big effect on how you will ride into corners, i did a bikesafe course in february wih the police, they focus almost entirely on road position and really does help you maintain speed through corners etc. Only costs £25 and they showed me lots of roads i didnt know about
T0MMY
PostPosted: 11:34 - 25 Apr 2010    Post subject: Reply with quote
As has been said, the bike will have far more grip than you expect if it's got even half decent tyres on it.
Circling roundabouts is definitely a good idea, you'll be surprised how far you can lean but just make sure you're smooth on the throttle.
On "real" roads just get to know a suitable stretch of NSL really well and concentrate on taking nice lines through the corners. Then build up the speed gradually to increase your lean angles.
ZX6R + CBR600RR
PostPosted: 11:39 - 25 Apr 2010    Post subject: Re: cornering technique Reply with quote
Bubbs wrote:
Hi all,
I'm not sure motorcycle cornering in one easy lesson is possible tbh.
However:
On the road you want to approach right handers in the left of your lane, and left handers as far right as possible without crossing the white line. You need to pick your speed carefully and make sure that the braking is all done before you reach your turn in point. It doesn't matter if you're slow at this point, its better to go in slow and come out fast than go in slow and come out in a hedge.
Imagine the point on the road where you want to turn in. Now move that point a few centimetres further into the corner. Keep that point in mind as you approach the corner but don't look at it.
As you reach that point with your front tyre, use countersteering to turn in and move your head to look through the corner. When you turn in you need what is known as 'maintenance throttle' which is where the throttle is not shut but you aren't accelerating hard, just accelerating a little. Almost just maintaining your speed but still accelerating. As you reach the apex of the corner you should see the vanishing point of the corner start to move away from you. As this happens you can start to open the throttle progressively and start accelerating as you bring the bike upright.
https://www.bikechatforums.com/files/lefthander.jpg
This crude diagram should give you a vague idea of your road positioning and the difference in turn-in points on a left hander. Most new/inexperienced riders turn in very early which gives you less of a view around the corner. Leaving the turn in a bit later (the green cross) allows you to see more through the corner, it allows you to not have to lean the bike over as far, and it gives you the full width of the road to use.
The red cross is an early turn in point where you have to crank the bike over more, you can't see what is around the corner and you've got to take a much wider line so as to not hit the inside edge of the corner.
The blue cross gives you a rough idea of the apex.
Now, the important thing to remember about my crap diagram is that it isn't to scale, so don't go barreling into a corner and turn in with your front wheel in the hedge.
Your brain will have a place where it feels it should turn in for a corner. In my experience, the ideal turn in point is usually a little bit further into the corner. Try pushing it further by a few CM, and see how your cornering improves. Don't push it too far though, because I don't want to be responsible for any accidents! If you want to really improve you need to do some advanced training really but unfortunately that isn't usually reccomended until you've been riding for six months or so.
Just remember to stay relaxed, keep your arms loose on the bars, keep your head upright while your body is leant over, drop your inner shoulder into the corner as you turn in, and look as far through the corner as you can manage using your pheripheral vision to see the turn in point and the apex.
Phew.
Here's an article I found on vanishing points:
https://www.cvam.info/index.php?page=main.tips_roadcraft_vanishing
CaNsA
PostPosted: 12:54 - 25 Apr 2010    Post subject: Reply with quote
I watched this a while ago, and found myself using the techniques mentioned in the vid without realising it.
"My primary objective in this DVD was to communicate to riders that there is a definite technology to riding. The bike wasn't designed by opinions or good advice and riding is the same, there are technical points that need to be understood. That's the message and focus of this film. Once a rider gets the idea there is a technology then and only then can he conquer his fears and uncertainties on cornering and at that point improvement is virtually unlimited." - Keith Code
Essential for all motorcyclists from weekend riders to racers, Twist of the Wrist II brings Keith Code's best selling book vividly to life, demonstrating precision techniques for overcoming barriers to cornering such as rider input, fundamentals on steering, visual skills, braking, body position, throttle control and more.
From canyon roads to track, techniques are fully explored and laid out using multiple camera angles, onboard shots and CG animation in over 105 minutes of spectacular Hi-Def footage.
The best performance upgrade for any rider, Twist of the Wrist II is the latest product from Keith Code, founder of The California Superbike School and trainer of numerous championship winning riders worldwide.
Clicky to torrent download
PostPosted: 14:30 - 25 Apr 2010    Post subject: Reply with quote
This chap posts loads of roadriding vids. https://www.youtube.com/watch?v=XxuN2_Z7eJI
I find myself saying 'keep out, keep out' when doing some right handers.
One of the best things about riding bikes is you never stop learning...if you want to.
Pat
bEN_
PostPosted: 18:58 - 25 Apr 2010    Post subject: Reply with quote
Fuck knee down, aim higher
https://www.youtube.com/watch?v=-TjR5uQoKNQ
2010 Ducati 848 Dark
Lamp Post Enthusiast
TUG
PostPosted: 19:21 - 25 Apr 2010    Post subject: Reply with quote
Its all aim and view for me, theres no point getting your knee down on blind bends right next to the curb.
I also counter steer alot, your head acts as a balance weight aswell, mines always right over but my seated posistion is as you would normally ride.
Slow in fast out!
Haz ER-5, innit!
L4Isoside
PostPosted: 20:19 - 25 Apr 2010    Post subject: Reply with quote
Gaz
Defo +1 on this.
One day knee down'ing next day i pumped up the tyres abit (too much, they warmed up and where 2 psi + over each tyre) and felt like i was gunna fall off the bike each corner.
Infact i almost did because i kinda bailed out mid corner and hit some gravel Shocked
evoboy
PostPosted: 21:25 - 25 Apr 2010    Post subject: Reply with quote
Just loosen up, relax and enjoy the ride.
Leaning the bike over further will come with experience. Have you had the bike long? Getting used to the bike is the first thing and as has been said, basic maintainence so you have confidence in the machine.
APT Motorcycles
R34lN1nj4
PostPosted: 22:14 - 25 Apr 2010    Post subject: Reply with quote
If it hasn't been mentioned before;
See if one of the lovely peeps from BCF will give you a hand in person. It's all very well taking on the advice, but sometimes if you see it put into pratice it will make it make sense better.
I suggest getting someone to follow you / you follow them and then you will see what you do differently to them.
A lot of cornering and leaning is down to confidence and experience though and that will only come with riding all the time. Get out there as much as possible and see what you feel happy doing.
A lot of the more experienced amongst us only got to where they are by having a scarey moment or ten, and it's only by realizing that you can get away with certain things that you learn more about the bike you are riding and the skill you possess.
...and as Evoboy said...
RELAX
[EDIT] I wont subject BCF to another copy of my KD by numbers picture, cos I can't find it.... [EDIT]
Smooth
PostPosted: 07:44 - 26 Apr 2010    Post subject: Reply with quote
As above, but also make sure that your bike is in good fettle. Give it a good service, set the suspension, check wheel alignment and all bearings, bushes etc. for play.
Try to be smooth and relaxed on the bike.
Before turning, press your outside knee against the tank. The turn is initiated by counter-steering, but it should be a fluid, natural, motion that is a by-product of looking far ahead and leading with your chin and torso.
TDM850
hmmmnz
PostPosted: 08:15 - 26 Apr 2010    Post subject: Reply with quote
in all my years riding. my only bit of insight is
brake before the corner, and accelerate through/out of it.
at no point during the corner let go of the gas or brake,
thats a sure way of going wide, or at worse high siding the bike..
the humans are dead
I kick arse for the lord
GSF Jamie 600
PostPosted: 08:19 - 26 Apr 2010    Post subject: Reply with quote
Trust your tyres Thumbs Up that used to be my problem, i just thoughught they wouldn't stick but now i have total confidence in them, they can go suprisingly far without even a slip.
And next time you fear leaning it over to much, think of itlike this, if you lean it over to much you will probarbly low side, which is a pain in the ass and hurts but if you come off the road you'll probarbly highside and fook they hurt lol
Oh and throttle control plays a huge part in it Thumbs Up
daz_d_biker
PostPosted: 12:21 - 01 May 2010    Post subject: Reply with quote
+1 on the trust your tyres thing. And if you have no faith in your tyres or are unsure if they're any good just go and buy a pair of new ones which you KNOW are good. A lot of the time it's a fear of not being able to make it around the corner which restricts your speed. Just relax and try not to think about it too much.
Also it helps if you can follow somebody that will go slightly faster than you're used to, even racers find it easier to go faster when they're following somebody faster than them.
The worst thing you can do is try and apply all of MarJay's advice all at once, because you simply will not be able to do it. (No offence to MarJay's advice- it's all good stuff!)
"bikes are replaceable - but a complete nutter aint."
metalangel
PostPosted: 13:24 - 01 May 2010    Post subject: Reply with quote
Just relax, come in slow and go out fast, keep steady throttle through.
LOOK where you want to go, and steer the bike towards it. A bit like 'padlocking' in air combat games, where you keep your gaze fixed on your target and then maneuver your plane towards it.
The last post was made 16 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 138.62 Kb
