Superbikes/sprockets question
Wilson1234
PostPosted: 20:20 - 06 May 2010    Post subject: Superbikes/sprockets question Reply with quote
So I know you can play around with the sprockets to altar how your bike does its job, and I'm quite certain that you can increase the already sufficient acceleration of say your GSX-R600, but I was under the impression that there's a level of acceleration where if you cross it, your front wheel is lifting, which I was also under the impression that having one wheel on the ground results in slower acceleration
I don't have a bike powerful enough to wheelie with just its power alone, so can someone explain to me what it's like with the maximum acceleration/wheelying thing?
How will playing around with sprockets help increase your acceleration? Or is my secondary information invalid?
Thinking
I'm aware that you can extend the swingarm, but I'm talking otherwise
These MC's wanna diss my baby mum
You're so lucky that I don't have a child
Swear to God, would've gone WILD, bust a mans face off the bathroom TILES
Swim41
PostPosted: 20:29 - 06 May 2010    Post subject: Re: Superbikes/sprockets question Reply with quote
Thinking
Wha? Confused
Yamaha XJ600N
PostPosted: 20:31 - 06 May 2010    Post subject: Re: Superbikes/sprockets question Reply with quote
You won't really increase acceleration in first gear noticably - as you say the limit is the front wheel coming up - the higher it comes the slower you are accelerating. However, second gear you may well increase acceleration and then more so relatively in the higher gears.
PostPosted: 20:40 - 06 May 2010    Post subject: Re: Superbikes/sprockets question Reply with quote
Thinking
Dropping the gearing will eventually mean that 2nd gear becomes the same as 1st used to be and so on. With first at such a low level the bike will probably be impossible to control at close to wide open throttle.
https://www.youtube.com/watch?v=QKsOGFh3Efk
Spit-Fire
PostPosted: 00:22 - 07 May 2010    Post subject: Reply with quote
that bikes used for stunting jay, so its gearing wont be similar to what you would use on the road
they say the good die young... i say we just live faster
PostPosted: 00:39 - 07 May 2010    Post subject: Reply with quote
If you gear the bike down to get more accelleration, and hit a point where you can't use more power without lifting the wheel, you can use a few tricks to help keep the front down.
You can reduce the tendency to wheelie by putting more rider weight over the front. You can just lean forward to move the rider weight or fit lower bars to naturally move your bodyweight forward. You can also reduce the pressure in the front tyre, really only good for dragracing as it will affect the normal handling of the bike.
You can lower the bike on the front or as a whole by dropping the forks through the yokes to lower the front or by changing the dogbones on some models to lower the rear or by other methods. This will lower the bike's center of mass.
You can soften the pre-load on the front and rear suspension. A harder suspension will make for easier wheelies, a softer one will make them harder.
You can use lowering straps on the front suspension to pull the front down and stop the forks extanding so the springs aren't 'helping' the front to lift. Not advisable on the road - really only a dragracing trick.
Wilson1234
PostPosted: 03:40 - 07 May 2010    Post subject: Reply with quote
Oh right. Thanks for clearing that up Thumbs Up
Now for my next question, what gears will lift the front wheel with power alone? On top end superbikes of course
Not including Tonyts' bike that will wheelie off just power in 7th Confused
Damon
PostPosted: 09:35 - 07 May 2010    Post subject: Reply with quote
I can get the front up in 1st and 2nd on the r1. But hit a big enough crest and it goes up in most gears with correct body positioning
PostPosted: 10:02 - 07 May 2010    Post subject: Reply with quote
Just about get the GSXR to lift it’s nose in 3rd under power on the flat – but it is very high geared, so we’re talking circa 100mph here.
Compare that to my KTM200 which I’ve had come up nicely in 4th under power on level (but rather bumpy) ground and it doesn’t sound so good – but the KTM is much lower geared and has a lot higher centre of gravity too.
PostPosted: 10:22 - 07 May 2010    Post subject: Reply with quote
Yes I know that Rolling Eyes it is just a demonstration of what happens when you downgear a bike too much...
PostPosted: 11:31 - 07 May 2010    Post subject: Reply with quote
Do you mean trying to lift the front wheel (ie, changing body position, etc, to encourage it), or lifting the front wheel anyway? The Bandit (not a stock engine) will lift the front wheel on a hard change into 3rd although not really a wheelie.
Wilson1234
PostPosted: 13:14 - 07 May 2010    Post subject: Reply with quote
Lifting on power alone, not encouraging lift at all
PostPosted: 15:37 - 07 May 2010    Post subject: Reply with quote
To do that you need a LOT of power. If you geared the bike low enough to lift in 6th then 1st and 2nd would be useless to you. Only thing it would be any good for is stunting.
I doubt you could actually get a suitably small front and large rear sprocket on most bikes to achieve it TBH. The chain would rub on something.
You could do it by putting a good bit of weight over the rear I guess, or shortening the swing-arm.
Spit-Fire
PostPosted: 14:23 - 08 May 2010    Post subject: Reply with quote
well its a poor example then isn't it mr?
as he isn't likely to go so far that he slaps a huge sprocket on it only suitable for stunting.
Razz Wink
The last post was made 16 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.36 - MySQL Queries: 14 - Page Size: 88.66 Kb
