Strip down of the top end, Suzuki GS125
The Artist
PostPosted: 18:55 - 09 May 2010    Post subject: Strip down of the top end, Suzuki GS125 Reply with quote
Today we thought it would be fun to take the top end off my bike and have a play around and make sure everything was ok.
https://bikechatforums.com/files/imag0012.jpg
https://bikechatforums.com/files/imag0013.jpg
https://bikechatforums.com/files/imag0014.jpg
https://bikechatforums.com/files/imag0015.jpg
https://bikechatforums.com/files/imag0016.jpg
https://bikechatforums.com/files/imag0017.jpg
https://bikechatforums.com/files/imag0018.jpg
Everything was ok apart from setting up the cam timing. Somehow by sheer luck the first time we put it back together it was180 degrees and 1 tooth out so the valves didn't hit the piston but it didn't start and just backfired very very loudly.
Figured out that we needed to turn it 180 degrees so off with the tank, electrics, cam cover, cct, cam timing gear and moved the gear round half way and put it on. It kind of ran but very sluggish so another tooth sorted that out.
There were no markings on the cam like described on the internet and in the workshop. Just a large chunk in the end which was horizontal at TDC.
After all this stress it was time to have a fag Laughing
CHR15
Turbo nutter bastard
PostPosted: 20:06 - 09 May 2010    Post subject: Reply with quote
by 'we' what he actually means, is he stood around smoking, while i did most of it.
The Artist
PostPosted: 20:10 - 09 May 2010    Post subject: Reply with quote
Did it for teh lulz
Ditto
PostPosted: 20:30 - 09 May 2010    Post subject: Reply with quote
Lol im currently putting off doing my valve clearances. Can't imagine stripping down my whole top end "for fun" Shocked
Although I would quite like to get a project bike to learn all about it. I know how most stuff works, but don't want to mess anything up on the only bike I have!
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
CHR15
PostPosted: 20:33 - 09 May 2010    Post subject: Reply with quote
get a project engine. youl pick up an old 4 stroke mower or something for a few quid, strip it and have fun.
once youve done one there all ( kind of ) the same.
a single cylinder 4 stroke is about the second simplest bike engine you can get.
Ditto
PostPosted: 20:36 - 09 May 2010    Post subject: Reply with quote
Yeah should have messed around with my CG more when I had it.
Barely touched it and bought an older Bandit once I sold it. Since then all the problems ive had, like stripping the carbs, have been made more difficult than they would have been if id just practised on the CG.
Never got round to the valve clearances on that either, so now looking at doing 16 instead of 2. Doh!
The Artist
PostPosted: 20:39 - 09 May 2010    Post subject: Reply with quote
Clearances are easy compared to removing valves etc.
Just make sure everything is tight when you re assemble.
The last post was made 16 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 54.69 Kb
