Will these SS downpipes clean up?
Andy C
Tree Seeking Missile
PostPosted: 21:19 - 25 May 2010    Post subject: Will these SS downpipes clean up? Reply with quote
Thinking of buying a system for my 400 but not sure if these pipes will clean up to look like new.
I was thinking varying grades of sandpaper and then lots of autosol:
https://i32.photobucket.com/albums/d20/andy13_uk/Random/Downpipes400.jpg
Think these will clean up?
mad4it028
PostPosted: 21:26 - 25 May 2010    Post subject: Reply with quote
they will clean up better but not like new but there chrome down pipes not stainless steel
Andy C
PostPosted: 21:27 - 25 May 2010    Post subject: Reply with quote
Thanks for the reply. How you know they are crome? How good you think they will turn out?
cb1rocket
PostPosted: 21:32 - 25 May 2010    Post subject: Reply with quote
there chrome pipe cos the finish has rusted!
Its basically a mild steel pipe(s) which is then electroplated using chrome metal (theres a proper name for this thou) which gives you the mirror finish when new. They go dull over time unless they are polished and cleaned regulary.
Chrome is pourus so water does get past to the base metal and rot
mad4it028
PostPosted: 21:36 - 25 May 2010    Post subject: Reply with quote
what he ^^ said Thumbs Up
Andy C
PostPosted: 21:41 - 25 May 2010    Post subject: Reply with quote
So they are unlikely to come out that great? Confused
I wont be able to get a refund as they are from Japan so want to be sure they will look good.
Do you think its likely that they have rusted properly as mild steel below?
The Artist
PostPosted: 21:54 - 25 May 2010    Post subject: Reply with quote
Stainless steel is exactly that...stainless.
Chrome rusts after a while because the steel underneath corrodes. You can probably get them looking almost new but will never be perfect and will corrode after any use in the rain or left outside.
They're always going to be rusty pipes. You could clean the rust up, but then you're going to be left with a steel area that will then just rust again.
The three options you would have are leave them as they are, spray them black, or use a bit of rust remedy to at least make the rust grey and more solid.
jimspeed
PostPosted: 21:56 - 25 May 2010    Post subject: Reply with quote
stainless pipes wouldn't rust like that. the rust is coming up thru the chrome plating and you will not stop it once it has started, even if you spent hours and hours cleaning them up they still wouldn't shine and would rust again as soon as they get wet
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Andy C
PostPosted: 22:00 - 25 May 2010    Post subject: Reply with quote
Thanks for all the replies. Thats a no no I think! (glad I asked before buying them Shocked ).
Since the Yen is so strong at the moment 130Yen to £ (use to be over 230Yen to £ occording to some website it prices out Japanese systems Sad .
Someone on 400GB suggested Preditor (predatormotorsport.co.uk) to cut the orginal system and put a new can on with a link pipe. Do you think this will look tidy? Anyone have any photos of a system done already?
Really dont want to cut the orginal system as in great condition Confused . But then I dont really like the sound of the orginal.
hhhhmmmmm
Paxovasa
PostPosted: 22:32 - 25 May 2010    Post subject: Reply with quote
There is a fourth option, get them rechromed Thumbs Up
Noxious89123
PostPosted: 22:53 - 25 May 2010    Post subject: Reply with quote
Actually, stainless can and will rust, just alot slower than normal steel. Stainless isn't "unstainable" it's stainless in the sense that it stains less. Wink
PostPosted: 23:43 - 25 May 2010    Post subject: Reply with quote
I didn't bother mentioning that as it's so expensive.
Ariel Badger
PostPosted: 07:41 - 26 May 2010    Post subject: Reply with quote
Most platers will not touch exhaust systems as the engine gunge inside them will pollute their chemical vats and require draining cleaning and replacing afterwards.
The last post was made 13 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.6 - MySQL Queries: 17 - Page Size: 90.9 Kb
