Kawasaki ZZR600D Project
unspec
PostPosted: 07:57 - 31 May 2010    Post subject: Kawasaki ZZR600D Project Reply with quote
After getting rear-ended by another bike last week I've got my hand on a tatty ZZR600 to keep me on 2 wheels. This will probably end up as my winter hack.
Phase 1
Get the bike running.
Pass MOT
Phase 2
Refresh braking, suspension and bearings. Light engine maintenance.
Phase 4 (tentative)
Cosmetic improvements.
So, this is what she looks like!
https://homepage.mac.com/jrsanderson/images/zzr600/garagea.jpg
The garage is getting a bit full...
https://homepage.mac.com/jrsanderson/images/zzr600/garageb.jpg
And this is the state of my Thundercat's generator cover.
https://homepage.mac.com/jrsanderson/images/zzr600/generator.jpg
[/img]
Next update will be my attempt to get this £390 bike started!
unspec
PostPosted: 16:32 - 31 May 2010    Post subject: Reply with quote
So things get off to a slow start, there are lots of things to check and possibly replace. I'm eager to get the bike running but the battery is shagged.
https://homepage.mac.com/jrsanderson/images/zzr600/batteries.jpg
So it was off to HG to get a new one, picked up a charger at 1/2 price as well. Love that deal Thumbs Up
https://homepage.mac.com/jrsanderson/images/zzr600/charger.jpg
I picked up a lot of other stuff I couldn't be bothered taking a picture of like new spark plugs, some semi-synthetic oil, carb cleaner, engine cleaner, oil filter, coolant, brake fluid and autosol - who says you can't polish a turd! Laughing
So while the battery charges overnight and the penetrating oil gets into some the of bolts I want to remove I had a bit of a play with the autosol to see if it could improve the look of the cans. It was ok, considering they aren't in the best of shape anyway..
https://homepage.mac.com/jrsanderson/images/zzr600/exhausta.jpg
Back to work tomorrow so I don't know how much will be done this week. Boo!
nightshaddow
PostPosted: 17:45 - 31 May 2010    Post subject: Reply with quote
looks like a start, shall follow Thumbs Up
steveh
PostPosted: 18:54 - 31 May 2010    Post subject: Reply with quote
nice, im not 100% sure but ive got a genny casing that you can have.
its from the 400 model but there all the same iirc.
steve.
unspec
PostPosted: 19:08 - 31 May 2010    Post subject: Reply with quote
steve.
It's a write off, still undecided if I will keep it. If I do I will give you a shout, thanks. Smile
PostPosted: 12:11 - 01 Jun 2010    Post subject: Reply with quote
I was thinking the exhaust was in unusually good condition for an early ZZR600.
unspec
PostPosted: 21:10 - 01 Jun 2010    Post subject: Reply with quote
Had an unexpected day off work (I actually forgot I had leave!) so I did a bit more on the bike.
Firstly I had a look at the brakes, the bloody thing was killing me when I was pushing it around. I was sure they were dragging.
Well the back brake was a state, I took the clips, spring and pins out and ended up with a hand full of rusty bits.
https://homepage.mac.com/jrsanderson/images/zzr600/handofbits.jpg
The corrosion had got to the pads as well...
https://homepage.mac.com/jrsanderson/images/zzr600/oldrearpads.jpg
I left the rear caliper on the bike without the pads - must remember not to push the rear brake lever when moving it about!
https://homepage.mac.com/jrsanderson/images/zzr600/rearcaliper.jpg
So the bike was easier to move around the garage but now the front was binding, not surprising really as there was a bit of corrosion there as well.
https://homepage.mac.com/jrsanderson/images/zzr600/frontbrakes1.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/frontbrakes2.jpg
I was too lazy to do the same to the front, and I hadn't put any penetrating oil onto the bolts like the rear brake, so I left it for later.
I then set about getting the tank off. To make it more easy to get to the tank bolts I took the rear fairings off.
https://homepage.mac.com/jrsanderson/images/zzr600/rearsubframe.jpg
I'm now getting a fair collection of bolts and washers - I must remember to buy a load of freezer bags to bag and label them up so I know where each lot came from.
The tank came off quite easily, clever Kawasaki even integrated a valve into the bottom of the tank, so you can just take the thing off and then hold it over a petrol container. That make getting rid of the stale fuel much easier then I had expected. Thumbs Up
With the tank away I was presented with the airbox.
https://homepage.mac.com/jrsanderson/images/zzr600/airbox1.jpg
That only took a few bolts and there was the inside of the airbox. I'd expected some spiders or even a dead mouse, but it was quite clean.
https://homepage.mac.com/jrsanderson/images/zzr600/airbox2.jpg
The filter also looked in pretty good shape, not as nice and a K&N but it will do for now.
https://homepage.mac.com/jrsanderson/images/zzr600/airfilter.jpg
I fired a blast of carb cleaner into carbs and put the airbox back together. I then went to check out the sparkplugs. I must have been quite excited as the picture came out all blurry.
https://homepage.mac.com/jrsanderson/images/zzr600/htleads.jpg
They were quite easy to remove, once I went on a totally redundant trip to Halfords to get a spark plug socket, finding they were out of stock then realising when I got home that I already had one Embarassed
They were pretty dirty - I put some new NGKs in just to be on the safe side. Thumbs Up
https://homepage.mac.com/jrsanderson/images/zzr600/oldplug.jpg
Tank went back on and the new fuel (with some Silkolene Pro FST) was added. All that was left was to pray that this was enough to start it.
I stabbed at the start button and after some struggling it fired into life again! Mr. Green There was a fair bit of smoke coming off the engine, most probably to the ACF50 I had been using to loosen up some stubborn rusty bolts but the bike was running at least.
It was getting late and I was getting hungry so I tidied up and got the 3 bikes back into the garage.
BTW I work really slowly that was basically a day of me faffing about. Embarassed
On my todo list
Sort the throttle - it is sticky and doesn't snap back to position.
Sort the brakes (front and back)
Grimnir
PostPosted: 22:45 - 01 Jun 2010    Post subject: Reply with quote
I have some zzr600 experience (see the thread noob - kinda):
176000 mile ZZR600:
I was a courier with a poorly R80RT and then I found a shop selling some damaged / repairables. 1.5 yrs old, 6.5k on the clock. It had been shunted from behind (stop sniggering), fallen off its stand and slid a little way. Needed 3 indicators & a rear mudguard to put it on the road plus soldering iron welding to fix the fairing & front mudguard. Followed by matt black spray paint.
Over the next 4 years it acquired various amounts of gonk tape / superglue / cableties due to 'interacting' with London traffic. Also Krauser panniers / top box / scottoiler / heated grips / handlebar muffs / 140w hi beam 100w dip.
It died at around 176000 miles. The insurance was way cheaper than the beemer as for couriers is was purely based on engine size. About 30% less thirsty too. Dispatching on a 'sports' (well, kinda) bike? Quite a few others have done it and given the cosmetic state I was hardly going to make it much worse without a serious lamp post interface. Sadly, all pics more than two years old were lost with my old pc Sad
PostPosted: 23:04 - 01 Jun 2010    Post subject: Reply with quote
176000 mile ZZR600:
176k miles? What was that like loosing a bike you had had for that long? I would have cried Laughing
BTW those front calipers are a bastard to work on everything will be seized, I do not envy you in the slightest.
unspec
PostPosted: 22:17 - 02 Jun 2010    Post subject: Reply with quote
I've put some penetrating oil onto the bolts. Hopefully get them off tomorrow. I've bought some freezer bags so I'll unmount the calipers and stick them in a sealed bag with a load of ACF50.
Didn't have time to do any work on the bike. Spent all evening typing up my accident report. Thumbs Down
PostPosted: 22:32 - 02 Jun 2010    Post subject: Reply with quote
I think CBR calipers of a certain vintage fit, maybe worth it if something turns up cheap.
CarlosCBR
PostPosted: 23:22 - 02 Jun 2010    Post subject: Reply with quote
Is that rear brake disk salvageable?
unspec
PostPosted: 23:30 - 02 Jun 2010    Post subject: Reply with quote
I just want to get it through the MOT, but if it looks like a real pain then I probably will go for the popular swap for the CBR nissins.
Doesn't feel too groved, I think a bit of elbow grease and a wire brush will restore it somewhat. I'm hoping anyway!
unspec
PostPosted: 00:15 - 04 Jun 2010    Post subject: Reply with quote
Just a quick update - didn't have time for a lot of work.
The penetrating oil on the caliper bolts had done the job, combined with my draper extension bar, I had them off in no time at all.
https://homepage.mac.com/jrsanderson/images/zzr600/draper.jpg
But the calipers were pretty corroded, it took a bit of effort just to get the screws that hold the spring plate off (one rounded and required me to break out the dremel, hammer and big slotted screwdriver) but by far the worst bit was the pin that holds the pads in place. The R clip wasn't any trouble but the pin on one of the calipers was seized solid.
https://homepage.mac.com/jrsanderson/images/zzr600/dirtycaliper.jpg
I ended up using a bit of penetrating oil, hitting it with a hammer then having a good idea to use a nail in the hole for the R clip and a set of pliers to rotate the pin. That was enough to break the corrosion holding it in place and with a bit of a tug, the pin came out. Thumbs Up
One top tip is to get a load of resealable freezer bags from the supermarket. They, along with Indian/Chinese take-away boxes are perfect for storing the bolts and pins from a bit of the bike. I like to keep similar bits together so I can reassemble a bit of the bike with the least hassle. As you can see I bagged up the items from the front calipers.
https://homepage.mac.com/jrsanderson/images/zzr600/baggedandtagged.jpg
After a bit of a clean with an old toothbrush and some brake cleaner I dried them off and left them on the bike. I'll cut some wood to use a block tomorrow to I can push the pots out and check the condition. The pads had a lot left in them luckily so the pots were hardly exposed at all to the elements. Smile
https://homepage.mac.com/jrsanderson/images/zzr600/restingcalipers.jpg
Grimnir
PostPosted: 10:38 - 04 Jun 2010    Post subject: Reply with quote
[quote="unspec"]
Those little screws were a complete biatch on mine but never had any problems with the pins.
The middle-top pad (?) looks like it has a crack in it, or is it carpet fluff?
Omega
PostPosted: 15:32 - 04 Jun 2010    Post subject: Reply with quote
I'm following this one with interest as I'm trying to do a similar thing with the same bike at the moment.
I'd really appreciate it if you could get a picture of where the horn is mounted if you get chance. I've still not found where it is supposed to go after mine snapped off last month lol.
unspec
PostPosted: 17:34 - 04 Jun 2010    Post subject: Reply with quote
I'm going to replace those little screws with some harder corrosion resistant stainless steel ones. The originals were proper Kawasaki cheese!
Yeah, there is no crack - just a lot of mess on the carpet Embarassed
The good thing about the pads is that there was a lot of material left in them, so the pots weren't exposed while the bike sat in a garage.
Gazdaman
I did a trackday!!!
PostPosted: 22:44 - 04 Jun 2010    Post subject: Reply with quote
This is a proper motorbike project thread! Looks like you're doing it well.
What's the bike's history? How did it get in such a state?
Gaz
unspec
PostPosted: 00:01 - 05 Jun 2010    Post subject: Reply with quote
Only did a little tonight as I'm feeling a bit crap with a cold. Sad
I cut some blocks of wood to sit in the calipers and popped them in.
https://homepage.mac.com/jrsanderson/images/zzr600/brakeblocks.jpg
Pumped the brakes and had a look at the pots.
https://homepage.mac.com/jrsanderson/images/zzr600/potsonshow.jpg
Not too bad! The line you can see mostly wiped off, some very light corrosion marks but it seems to be cosmetic. We'll see when I bleed them. I'd like to smarten the calipers up but I just need them to work at the moment so I will resist the temptation to get new bolts/bleed nipples/gold paint. I will give them a good scrubbing with a wire brush and then a wipe down with ACF50 on a rag to kill the corrosion.
The only other thing I did was have a close look at the forks, I hadn't seen any sign of fork oil leaking but I didn't know how bad the corrosion was.
https://homepage.mac.com/jrsanderson/images/zzr600/forkcondition.jpg
So, not that bad at all. If I have time I might drop them out, polish them up so they look more cared for when it goes in for the MOT.
unspec
PostPosted: 00:07 - 05 Jun 2010    Post subject: Reply with quote
Gaz
Clock are all in kilometres, so I'm assuming it is a grey Jap import. The rear fairings are painted in an interesting colour but are in rather good condition. Sadly the front fairing is quite tatty, looks like a non-original fibreglass replacement that has taken a bit of a battering.
There are a few signs of some spills but nothing too severe. Some scuffing on the engine covers. The braided hoses and of the small things I have noticed here and there (like the almost new air filter) show it was cared for at some time. But the chap I bought it off had a nasty spill around 2006 and hurt his leg. I believe the bike sat in the back of the garage after that until I bought it.
TUG
PostPosted: 00:13 - 05 Jun 2010    Post subject: Reply with quote
Those calipers... do the pistons easily slide back into the caliper? If not take apart and scrape out the corrosion and clean up the pistons.
Haz ER-5, innit!
Grimnir
PostPosted: 11:09 - 05 Jun 2010    Post subject: Reply with quote
When you get your new bleed nipples / bolts sit them in a 'bath' of fresh brake fluid / gently flush them through with a syringe before fitting. Helps the fluid flow when you fit them and can cut down on bleeding time. Also only remove / fit one bolt / bleed nipple at a time - you don't let so much (almost none if you are good) air into the system.
Unless you want to change the fluid anyway, which would be a good idea as it has been standing for a while. Flush the fluid through and see when it runs clear. Tighten. Bleed. Next caliper. Don't forget the back.
Even if you are doing the full fluid change at the same time as the bolts - still give them a good bath first.
unspec
PostPosted: 20:47 - 05 Jun 2010    Post subject: Reply with quote
Sorry I didn't do a lot today. I've got the sweats and a rotten cold/cough. Sad
I cleaned up the calipers and put them back in, topped up the brake fluid and bled it. Brakes aren't sticking now but do feel a bit soft, I will have to check some air hasn't gotten in...
https://homepage.mac.com/jrsanderson/images/zzr600/cleanedcalipers.jpg
Topping up the brake fluid was easier said then done as someone had stripped one of the screws on the cover and let it rust. Sad
https://homepage.mac.com/jrsanderson/images/zzr600/frontmc.jpg
I then took it out onto the drive to see if it worked. I still have a problem with the engine, it just won't idle properly. If I'm feeling up to it, I will get the carbs out and give them a damn good clean.
https://homepage.mac.com/jrsanderson/images/zzr600/zzr600d-001.jpg
As you can see, the front brakes are (re)bedding in.
https://homepage.mac.com/jrsanderson/images/zzr600/frontdiscs.jpg
And with that I'm going to watch the racing on my V+ box. Gutted about the news on VR64 Sad
unspec
PostPosted: 21:03 - 06 Jun 2010    Post subject: Reply with quote
Well today I decided to do something about the sticky throttle and look at the carbs.
So, I started with the throttle control.
https://homepage.mac.com/jrsanderson/images/zzr600/throttlebody.jpg
Didn't take any effort to open it up.
https://homepage.mac.com/jrsanderson/images/zzr600/throttleapart.jpg
That put enough slack in the throttle/return cables to think about taking the carbs off. Another tip, a freezer maker pen and duct tape is a really easy way to label stuff. Smile I did that to remember where the vacuum tubes connect.
https://homepage.mac.com/jrsanderson/images/zzr600/remembertolabel.jpg
With that in mind I slackened off the seals that keep the carb unit attached and popped it off. It was a bit of a fiddle getting the throttle/return cables off but overall not too tricky. I then stuffed some clean rags into the holes.
https://homepage.mac.com/jrsanderson/images/zzr600/petrolsoakedrags.jpg
A bit of fuel dribbled out of the unit onto the rags when I was getting them off - the garage now stinks of petrol and it was giving me a headache (even with the garage door wide open!).
But I had achieved my goal, I got the carbs off.
https://homepage.mac.com/jrsanderson/images/zzr600/carbsoff.jpg
Next will be cleaning the carbs and checking the throttle cables. The spring on the carb unit was smooth and strong. The throttle cables when they were detached seemed to move freely but when it was all connected up the throttle just wouldn't return? I guess I will just lube them up and spend a bit of time adjusting them. Hopefully that will cure it. Smile
unspec
PostPosted: 21:20 - 06 Jun 2010    Post subject: Reply with quote
Sorry just noticed your post.
I will take a picture of the (rusty) horn and the (equally rusty) mounting point next time I'm snapping away. Smile
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 144.26 Kb
