PEUGEOT SPEEDFIGHT 2 PROBLEMS!!!!!!!!
chaddy1211
PostPosted: 09:32 - 05 Jun 2010    Post subject: PEUGEOT SPEEDFIGHT 2 PROBLEMS!!!!!!!! Reply with quote
hi i have just got a peugeot speedfight 2 50cc lc
i had the bike given to me so i dont know much about it , the kickstart was not working so i took the cover off and sorted that problem out then i replaced the battery the bike will still not start even tho i have got compression to the engine , there are no lights working at all or on the dash or the electric start the only thing that works is the horn
i have also notice that it has got a peugeot elyeso cdi unit on it
please help as i would lyk to get it goin soon as possible
thanks
j. chadburn
Paxovasa
PostPosted: 09:38 - 05 Jun 2010    Post subject: Reply with quote
Check the fuses, check the earth and check the ignition. Thumbs Up
chaddy1211
PostPosted: 09:45 - 05 Jun 2010    Post subject: Reply with quote
hi have checked the fuse now im not sure about the earth or the ignition as i am new to this please could you explain abit more thanks
j. chadburn
Paxovasa
PostPosted: 09:48 - 05 Jun 2010    Post subject: Reply with quote
With regards to the ignition when turned on check with a multimeter that power is getting to it, the electrics should be earthed to the frame.
Also check the connections onto the battery terminals are clean and tight.
chaddy1211
PostPosted: 09:54 - 05 Jun 2010    Post subject: Reply with quote
ok thanks now regarding the different cdi unit ow do i cross that problem
j. chadburn
Paxovasa
PostPosted: 10:11 - 05 Jun 2010    Post subject: Reply with quote
What problem?
That cdi de-restricts the bike, do you want to put an OE cdi back on the bike?
chaddy1211
PostPosted: 10:23 - 05 Jun 2010    Post subject: Reply with quote
i just thought it would be a problem with it havin a different cdi unit on it the cdi unit says chipkey 2 elyeso and the bike has been stood a couple of years
j. chadburn
The last post was made 16 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 14 - Page Size: 50.32 Kb
