gs500 engine mount bolt!!
dransy
PostPosted: 20:24 - 10 Jun 2010    Post subject: gs500 engine mount bolt!! Reply with quote
Yes the front one! as always!!
How the feck can i get it out! my god!
Ive even rang up a couple of garages and they said they wont do as it is too much hassle.
Ive had one out in the past by using the blow torch , lump hammer and spanner it took me ages but i got it out!
Now this one i cant get out! What would be the safest way to get it out? i was thinking of grinding of the ends and drilling through where its seized in?
Piece of shit!!!
hmmmnz
PostPosted: 20:33 - 10 Jun 2010    Post subject: Reply with quote
can you get the nut off??
if so thats half the battle,,
failing that, grind the fucker free, then use a big bar and socket and try and loosen the bolt, then use a drift and whack the fucker free
grease up the new one Mr. Green Thumbs Up
the humans are dead
I kick arse for the lord
el_oso
PostPosted: 22:07 - 10 Jun 2010    Post subject: Reply with quote
i had to cut the thing out. sometimes it is the only way.
once i had the bolt out the frame i tried drilling the bolt out so that i could save the mounting rubber thing. took ages even with WD-40 to cool and lubricate the drill bit.
i tried using a drift with a big muther fuking hammer and a breaker bar over a foot long. still wasn't budging. got to the point where i was beginning to lift the bike off the floor. (couldn't push down as the frame was in the way)
Duke 390
Car: Jeep Wrangler 4.0L
T1z3R
PostPosted: 23:08 - 10 Jun 2010    Post subject: Reply with quote
ive had to cut two off so far.
i drill the heads off them then remove the rest when the engines out of the bike.
duck my sick!
dransy
PostPosted: 18:55 - 11 Jun 2010    Post subject: Reply with quote
The engine is out of the frame , i bought the engine of some guy and he had to grind the of the mount on the frame to get out the engine.
I was going to grind of the 2 ends then drill it out where its seized in.
see pic
https://www.bikechatforums.com/files/gs500_engine_bolt_as.jpg
edit, the left spacer is already of
T1z3R
PostPosted: 22:15 - 11 Jun 2010    Post subject: Reply with quote
i would grind through the bolt just left of the inner face of the left bush then drill into the bolt removing the rest of the face then knock the remaing bolt out with a drift.
duck my sick!
The last post was made 16 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.33 - MySQL Queries: 14 - Page Size: 48.36 Kb
