yzf 600 thundercat / fzr 600 engined swap.
biker_king
PostPosted: 21:44 - 07 Jun 2010    Post subject: yzf 600 thundercat / fzr 600 engined swap. Reply with quote
hello people, i have a yzf thundercat with a broken gearbox main shaft i, i have decided to replace the engine insted of striping it for repair. i have found a cheap fzr 600 engine was just wondering if anyone has done this swap and knows if thies engines share the sames mounts , loom conections ect.
thanks for any help, james.
temeluchus
PostPosted: 21:50 - 07 Jun 2010    Post subject: Reply with quote
The engines are similar, but i couldnt tell you if the mounts are identical and I doubt the electrics are identical.
PostPosted: 22:31 - 07 Jun 2010    Post subject: Reply with quote
CHR15 wrote:
The Fazer and the Thundercat have identical engines except for cams IIRC, and both of these engines are derived from the FZR. Engine mount wise both should be the same, but as someone said I've no idea what happens with the electrics.
Phoenix
Twisted Firestarter
PostPosted: 23:18 - 07 Jun 2010    Post subject: Reply with quote
I'd expect the FZR engine to be more similar to the thundercat than the Fazer, the Thundercat was essentially the replacement for the FZR600. The engine mounts could well be the same too.
andys675
PostPosted: 16:52 - 08 Jun 2010    Post subject: Reply with quote
what you want is a 94/95 FZR600 foxeye engine (the one that looks like a YZF750) the frame, tank and wheels etc are more or less the the same if you don't look at the fairing
daveg
PostPosted: 11:19 - 09 Jun 2010    Post subject: Reply with quote
fzr 600r 94-96 engine and thundercat are basically same engine just different pistons, airbox assembly, if you get 94-95 engine it is about 85-90 bhp but 96 engine is 100 bhp same as thundercat.
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.42 - MySQL Queries: 14 - Page Size: 48.49 Kb
