| bruce_lee_22 |
 bruce_lee_22 Renault 5 Driver
 Posted: 20:52 - 05 Jun 2010 Post subject: Honda VFR400 NC 30, Clutch Problem |
wondering if anyone can help me please.
recently my clutch started Dragging, so i checked the clutch
and needed new friction plates, i put my new friction plates in recently, and for some reason the clutch doesnt work at all? any ideas? then i tried again 30 minutes later, put it in first gear and the clutch 'Bit' but very late, then tried it in 2nd gear and it wouldn't bite, tried it in 1st wouldnt bite? so very rarely it will be, and mostly not at all? can someone please help me? ____________________ VFR 400 & RVF 400 |
| Frost |
 Frost World Chat Champion
| bruce_lee_22 |
 Posted: 21:17 - 05 Jun 2010 Post subject: |
hiya mate, my brother is a level 3 trained mechanic, and weve, done the adjuster fully, he built the clutch back as you said, friction plate, steel plate etc, and the push rod/actuator arm is in correctly, so were a bit clueless on what it can be? you can feel pressure when you pull the lever etc, but it just isn't biting, does 1/10 times as ive said :S any other ideas matey? ____________________ VFR 400 & RVF 400 |
| Frost |
| bruce_lee_22 |
 Posted: 22:16 - 05 Jun 2010 Post subject: |
yeah topped the oil up, took 2 1/2 litres, its castrol GP1 oil or something, semi synthetic, cost like £29 for 4 litres, but yeh topped it up, and also done the friction plate,steel plates alternating as you said, made sure the actuator arm was properly in place, checked the tension and its been adjusted so there's no slack or play, but it just doesnt seem to work at all? =/ ____________________ VFR 400 & RVF 400 |
| prawny1 |
 prawny1 World Chat Champion
| bruce_lee_22 |
| Frost |
| bruce_lee_22 |
| bruce_lee_22 |
 Posted: 14:06 - 08 Jun 2010 Post subject: help please! |
can anyone think of what it could be  ____________________ VFR 400 & RVF 400 |
| Gazdaman |
 Gazdaman I did a trackday!!!
| bruce_lee_22 |
 Posted: 15:34 - 08 Jun 2010 Post subject: |
no we didnt replace the springs but i think i know why its not working now, because the clutch was dragging, so the overall thickness of the clutch assembly was slightly thicker, therefore stretching the springs, and now cause its stretched its no longer exerting enough force to engage the clutch properly i think shall go see! ill let you know Thanks!  ____________________ VFR 400 & RVF 400 |
| bruce_lee_22 |
| Gazdaman |
| bruce_lee_22 |
| Frost |
| finpos |
 finpos World Chat Champion
| stinkwheel |
 Posted: 23:24 - 08 Jun 2010 Post subject: |
I don't know if it's like the clutch on the VFR750 (ok, they are very diferent bikes but not an unreasonable thought).
If it is, one of the friction plates is a different shape to the other ones. It goes in the basket first. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Frost |
| stinkwheel |
| bruce_lee_22 |
| bruce_lee_22 |
| bruce_lee_22 |
| Frost |
| bruce_lee_22 |
The last post was made 15 years, 246 days ago. Instead of replying here, would creating a new thread be more useful? |
