Flaming exhaust
Mox
PostPosted: 07:59 - 09 Jun 2010    Post subject: Flaming exhaust Reply with quote
Hi all, my exhaust flames when shifting up through the gears. What causes this? It is an aftermarket performance exhaust.
I know that it would be unburnt fuel igniting.
Is this a bad thing for the engine?
It sure looks cool, but I don't want to bugger up the bike.
VFR400 NC30
temeluchus
PostPosted: 09:39 - 09 Jun 2010    Post subject: Reply with quote
are we talking the odd little flash, or FLAMES!?
If its fire, then youll need to check your carburation.
DJH
PostPosted: 09:46 - 09 Jun 2010    Post subject: Reply with quote
How big are the flames? Pics needed mate. Cool
Paxovasa
PostPosted: 09:50 - 09 Jun 2010    Post subject: Reply with quote
You will need to sort out the mixture setting.
temeluchus
PostPosted: 10:23 - 09 Jun 2010    Post subject: Reply with quote
if its a loud pipe, its not unusual to get a few little flashes as when the engine is on the overrun with the throttle closed, unburnt fuel (you will always have a little) collects and combusts in the pipe.
MonkeyKnuckle
PostPosted: 12:38 - 09 Jun 2010    Post subject: Reply with quote
My old CBR600F used to do it when revving high. Looked cool as. Cool It was just a little flash, not a flamethrower type jobby.
No idea if my new bike does it but it's an underseat pipe so I'd be worried about setting my arse on fire. Laughing
MKGaming.com
tutton
PostPosted: 12:52 - 09 Jun 2010    Post subject: Reply with quote
Thought flames up top of revs are it running lean?
as when you touch the limiter it stops the fuelling and is still getting cack loads of air?
Coming down through on over run as well, its getting minimal fuel but loads of air?
Walloper
PostPosted: 13:17 - 09 Jun 2010    Post subject: Reply with quote
It is a common problem with those auld Petronas' FP1 Roadsters. Smile
For sure it's a carburettion issue.
The carbs should be tuned to the exhaust by rights.
Most folk don't bother as tuning has no effect whatsoevah on how much noise the endcan permits. (Which seems to be the main reason for fitting after market exhausts.) Razz
Pickledswede
PostPosted: 13:46 - 09 Jun 2010    Post subject: Reply with quote
Just noticed the advert at the bottom of this thread...
Exhaust Flaming flamer kit
99p buy it now! Laughing
The last post was made 16 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 14 - Page Size: 58.59 Kb
