rear shocks for 90s sports bike
hornetmike
PostPosted: 16:49 - 04 Jul 2010    Post subject: rear shocks for 90s sports bike Reply with quote
I've read lots about shocks wearing out, but where do you go to buy a new one? I can only find hagon in bike mags.
What about front forks can they get up graded, mine need powder coating to.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Flip
PostPosted: 16:56 - 04 Jul 2010    Post subject: Reply with quote
What is wrong with Hagon?
You can upgrade the fork springs or use a thicker oil.
Mungel
PostPosted: 17:05 - 04 Jul 2010    Post subject: Reply with quote
These guys have been recommended to me.
https://www.kais-performance.com/contact.htm
Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S
swiftb
PostPosted: 17:08 - 04 Jul 2010    Post subject: Reply with quote
How many miles has your bike done? Couple of possibilities. Replace the standard shock with a much lower mileage standard shock. Replace it with a shock from a newer bike which fits without any (or too much) modification.
You could obvioulsy buy a Hagon, or something a bit more expensive. But your talking £200-£300 for a Hagon then £500+ for anything from any of the bigger manufacturers. Is it worth it for an old bike you have to ask yourself.?
My suspension was worse for wear, year2000 with 30k on the clock. I replaced the standard shock with a low mileage standard example, replaced the fork oil to match my weight and spent a lot of time setting it up to my weight and riding preferences.
Time and money well spent, but done extremely on the cheap as apposed to splashing out on expensive gear for a 10yr old 30kmiles bike.
EDIT: you asked about uprgrading forks, of course it can be done by the likes of K-tech etc with uprated springs, better components etc but you should be able to get much improvement just by replacing the oil to match your weight, replacing any worn bushings etc and replacing springs if they are no longer in tolerence. Also, I would advise simply painting your own fork legs. Very easy to do with rattle cans for a great finish.
kestrel
PostPosted: 17:21 - 04 Jul 2010    Post subject: Reply with quote
Try Bike Revival, good selection of budget shocks.
here:
https://www.bike-revival.co.uk/
Noxious89123
PostPosted: 23:15 - 04 Jul 2010    Post subject: Reply with quote
Sod buying a second hand shock with lower mileage. So long as your shock isn't disgustingly corroded or "broken" in anyway, just get it refurbed. New seals, bushes and oil. Should be cheaper than a second hand shock, and give better results.
I had my shock and forks refurbed, to make them feel how they would have done when the bike first rolled out the factory. The forks were pretty good to start with, the shock not so much. The difference it made to the shock was huge, there is so much more damping and it feels alot smoother.
I had mine done by K-Tech. Was about £85 for the shock and about £100 for the forks iirc. That included the cost of new oil, seals and bushes as well as labour.
D O G
PostPosted: 09:28 - 05 Jul 2010    Post subject: Reply with quote
Racetech do rebuild kits for shockers and excellent upgrades for forks too - bringing older spec items up to modern performance levels.
They're American, but ship to the UK, and I found their products good in the past, and pretty cheap. Hoping to buy some stuff to redo the SRAD suspension at some point.
swiftb
PostPosted: 14:47 - 05 Jul 2010    Post subject: Reply with quote
Noxious89123 wrote:
Sod buying a second hand shock with lower mileage. .
Mine cost me £35, and its a massive improvement over the one I had. Although admittedly there is a bit of a gamble when buying a used shock - but if you get a good one it beats paying £85-£100 for the shock to be rebuilt, and the time your bike is off the road waiting for this to be done also.
I was also under the impression a lot of standard shocks cannot be rebuilt/refurbed.
hornetmike
PostPosted: 19:44 - 05 Jul 2010    Post subject: Reply with quote
Cheers, k tech rebuilds sounds good, spending loads on 96 CBR probably isn't clever.
Although while my shocks are off I might powder coat my wheels Smile.
CRF_Rider
PostPosted: 20:43 - 05 Jul 2010    Post subject: Reply with quote
+1 for K-Tech, great guys. Did my CRF for me, £200 fully setup inc lowering of the front forks. Good service and i'll deffinatly use them from now on.
Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp
The last post was made 16 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 14 - Page Size: 65.25 Kb
