| Carvel |
 Carvel World Chat Champion
 Posted: 23:57 - 05 Jul 2010 Post subject: RXS fork springs |
Just a quickie, does anyone (cows) know if and if so where I can get a new set of fork springs for my RXS as it's all getting a bit soft upfront .
ta
Ollie. ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
Matt B: I can deal with crushed nuts to beat Ollie. |
| Paddy Blake |
 Paddy Blake World Chat Champion
 Posted: 01:42 - 06 Jul 2010 Post subject: |
You will find it here.
https://www.wemoto.com/bikes/
Type in what the bike is called in the log log book.
If you cant get them then put some spacers in. |
| 27cows |
 27cows World Chat Champion
 Posted: 06:00 - 06 Jul 2010 Post subject: |
Far as I know it's not possible to buy replacement springs for the RXS, other than ordering via a Yam dealer to have them sent from Japan (and they'd be ridiculously expensive).
It's more likely you just need to change the oil. Standard RXS forks are a bit slack at the best of times. They have short springs and long spacers. I replaced mine with longer springs and did away with the spacers. Not sure if they were standard but the ones I used came out of a crashed RD125 twin and are a large improvement over the originals.
If you do change the oil, would recommend using 20w.
Be warned - getting the RXS fork tops undone can be a challenging experience, to say the least  ____________________ The RXS100: vehicle of choice for Chuck Norris |
| Carvel |
| 27cows |
 Posted: 18:25 - 06 Jul 2010 Post subject: |
Fork seals can be a total bastard to get out if the white corrosion has set in and bubbled the lacquer. Ideally you should carefully sand out the seal seat before drifting the new ones in with a (think I use a 30mm) socket. But I doubt the new ones will leak - they're pretty tough.
It's extremely common for the mudguard bolts to seize in. Sometimes attempting to get them undone results in the whole thread part of the fork breaking away. I always use stainless socket caps, with washers, and the threads coated with copper grease to overcome the problem:
https://i219.photobucket.com/albums/cc223/Funkdooby_album/Dscf0532.jpg ____________________ The RXS100: vehicle of choice for Chuck Norris |
| Carvel |
The last post was made 16 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
