| P_J |
 P_J Nearly there...
 Posted: 21:05 - 20 Oct 2003 Post subject: Carb Icing |
What is "Carb Icing", and no jokes about cakes or other fine desserts please.
Also, anyone got any ideas why, on the way home tonight, my bike was whistling like it had a turbo. Quite a high note but not a squeal, and seemed to be when reving up and when it was coming down too(what is that called when the rev's are dying down?). It wasnt loud but i could hear it at low speed with visor down, not sure if was still at high speed because of the wind.
PJ ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| McJamweasel |
 McJamweasel BCF Junkie
 Posted: 21:08 - 20 Oct 2003 Post subject: |
Its where the carb gets cold and ices up!  ____________________ BCF: Be yourself, just don't be an arse. |
| Scotty |
 Scotty Scooter Boi
| P_J |
 P_J Nearly there...
 Posted: 21:10 - 20 Oct 2003 Post subject: |
which causes?
Damage?
Stalling?
crap performance?
And are we talking the inside or outside parts?
Only1PJ.co.uk |
| McJamweasel |
| Scotty |
 Scotty Scooter Boi
| P_J |
 P_J Nearly there...
| McJamweasel |
| WildGoose |
 WildGoose White Van Man
| Kickstart |
 Kickstart The Oracle
 Posted: 23:39 - 20 Oct 2003 Post subject: |
My old FZ used to suffer from it badly. Would drop from 45mpg to 25mpg, and would not run below 4000rpm.
Basically the fuel being drawn from the carb takes alot of heat with it. Eventually the carb gets really cold and starts to freeze the water in the air going through.
On my old MBX125 I once had carb icing like problems, looked down at the carb and the outside was covered in frost.
| Craig_ |
 Craig_ Trackday Trickster
 Posted: 23:51 - 20 Oct 2003 Post subject: |
Carb Icing is where you get the icing sug... ahh wait you said no jokes about cakes.
Yeh its just the carbs freezing up and causing a non starter or a sack of shite feeling, wont cause damage, can clear up when engine gets hot.
Heater idea is good to. ____________________ VAG Cars - www.vagcars.co.uk - North East VAG Owners Club |
| McJamweasel |
| Kickstart |
 Posted: 00:08 - 21 Oct 2003 Post subject: |
The additives does work but is expensive.
Most Kawasakis direct some coolant through the carb float bowls to warm them up a touch. Kawasaki had a big problem with carb icing about 15 years ago and had to recall pretty much every liquid cooled 4 stroke they had sold in the UK to fit them with new carbs.
Injectors work at a hell of a preasure. Don't think they suffer from it.
| Craig_ |
 Posted: 00:12 - 21 Oct 2003 Post subject: |
My RS50 had a coolant line running through the manifol to get the heat there. ____________________ VAG Cars - www.vagcars.co.uk - North East VAG Owners Club |
The last post was made 23 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
