peugeot speedfight 100 wont pick up
chaz e z
PostPosted: 20:05 - 16 Nov 2009    Post subject: peugeot speedfight 100 wont pick up Reply with quote
Hi im new here, iv just finished rebuilding my peugeot speedfight 100 and tuned every part of the engine. Its been starting after 1 press of the electric start. One night after it had been outside for about 2 hours i it was hard to start but i got it going then it cut out after a couple of seconds and wouldn't restart. When i press the electric start now it nearly starts but doesnt pick up, i have a spark and theres petrol coming through. I took off the barrel and piston and there was loads of petrol in the crank area, the petrol was black in the bottom for some reason. i drained it and still wouldnt pick up. The plug is soaking, Thanks for the help
Peugeot Speedfight 100cc (Fully tuned but confused!)
Vespa PK 135 (Fully tuned)
18 and live in Hull
steo
PostPosted: 05:45 - 17 Nov 2009    Post subject: Reply with quote
Did you happen to change the cdi or ignition? Because of the immobiliser the chipped ignition key has to match up with the cdi & if it doesn't the scoot will start okay but wont rev up & drive.
PostPosted: 08:45 - 17 Nov 2009    Post subject: Reply with quote
im thinking theres oil getting in and mixing with your petrol.
You said you fully tuned it, i take it you stripped the whole thing apart.
Did you put all new gaskets in? leave any bolts out...because black petrol sounds like a mix of petrol and oil.
chaz e z
PostPosted: 16:42 - 17 Nov 2009    Post subject: Reply with quote
i stripped the whole engina, i putin new gaskets and had no bolts left over. It had been rumming fine for a week till now. Where would the oil come from? It won't be able to come from the gearbox would it?
18 and live in Hull
PostPosted: 22:36 - 17 Nov 2009    Post subject: Reply with quote
Thats the only place it would come from i think.
Thats where you put the engine oil.. and if its mixing with the petrol its getting through somehow.
prawny1
PostPosted: 18:35 - 18 Nov 2009    Post subject: Reply with quote
Not going to be an oil problem as the gearbox is at the other end of the engine and sealed, the two stroke pump could be incorrectly adjusted but that in itself would cause smoking not flooding.
It is likely to be a stuck float valve, or very rich jetting causing the engine to flood, or it could be the vacuum tap leaking internaly.
chaz e z
PostPosted: 23:28 - 19 Nov 2009    Post subject: Reply with quote
iv checked and the gearbox oil isn't getting through, i havent touched the cdi or ignition. The boke doesn't start, it nearly does but doesnt pick up. It was only stood for 2 hours so i dont know how it would be the immobiliser. When i tried to start it today it backfired. The timing can't be out in anyway can it? Im putting on a new fuel tap tomorrow because i had a lambretta one on before but it had been working with that on for months
18 and live in Hull
chaz e z
PostPosted: 17:46 - 20 Nov 2009    Post subject: Reply with quote
iv checked all the carb it fine and got a new vacuum pump but i am currently premixing at the moment because my oil pump cable has snapped. I cleaned out the tank today and put in just petrol but stil wouldnt start
18 and live in Hull
There is a gap of 237 days between these two posts...
speed fighter
PostPosted: 22:51 - 15 Jul 2010    Post subject: Reply with quote
change your spark plug i had same problem with my speed fight hope it helps
baldy
PostPosted: 21:32 - 16 Jul 2010    Post subject: Reply with quote
It sounds to me as one of your crank seals has gone. My brother had the same problem. It floods the cases because it can't suck the fuel into the engine to burn. Also make sure your float valve is ok.
One day i will rule the world, just not today.
duzzer
PostPosted: 12:36 - 17 Jul 2010    Post subject: Reply with quote
if his seals have gone then it wont suck any fuel,,,
whats ur set up, am 1 of the most experiance lads when it comes to tunning the fb6/fb7 engine's so dont bull s**t me,,, i will help you on pug club.co.uk Very Happy
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.09 - MySQL Queries: 14 - Page Size: 67.24 Kb
