Ariel S*HT
Ariel Badger
PostPosted: 21:38 - 30 Jul 2010    Post subject: Ariel S*HT Reply with quote
I brought a 1950s Ariel 500cc HT Trials bike a few months back. I have no interest in riding trials ( I am rubbish at going slow) but I knew this machine had previously been subject to some serious tweaking and could be the basis of a competitive freak hillclimb bike. She rode ok but felt a little soft and there were flat spots on acceleration.
The Trials frame is very lightweight and was only used on the competition machines, the engine is lightweight all aluminium but in a soft state of tune although a highly tuned version of this motor was used in the HS Scrambler but in a heavy weight frame. Why Ariel never combined the light frame with the hot engine is anyone's guess but the politics of the time had Ariel as a subsidiary company to BSA and a bike like that would have been a direct challenge to the BSA flagship, the Goldstar.
Any way I decided to rip her down and see what I had.
Over the last few weeks I made some calls and obtained a Scrambler camshaft and cam followers and as the kids were not in school this week I took advantage of our workshops and got the spanners out.
Please forgive the multi-posts but my browser keeps crashing
PostPosted: 21:40 - 30 Jul 2010    Post subject: Reply with quote
Pass the popcorn
Ariel Badger
PostPosted: 21:49 - 30 Jul 2010    Post subject: Reply with quote
Howling Terror wrote:
Pass the popcorn
I will put pictures up tomorow Google Chrome and a ferret make posting impossible ATM Very Happy
PostPosted: 21:54 - 30 Jul 2010    Post subject: Reply with quote
Pass the popcorn Pass the popcorn Pass the popcorn ...That should last till the Ferret & Chrome behave.
The Original Muzza
PostPosted: 13:17 - 31 Jul 2010    Post subject: Reply with quote
...because Ariel's too cool for a cool story bro:
https://www.esportsea.com/global/media_preview.php?url=http%3A%2F%2Fcdn1.knowyourmeme.com%2Fi%2F20854%2Foriginal%2FRiveting_tale_chap.jpg
CHR15
Turbo nutter bastard
PostPosted: 18:28 - 31 Jul 2010    Post subject: Reply with quote
as if we have to wait till tomorrow for pics!!
Crying or Very sad
Teflon-Mike
tl;dr
PostPosted: 17:19 - 01 Aug 2010    Post subject: Reply with quote
Crying or Very sad
Guess that makes this an Aerial leader........
Ariel Badger
PostPosted: 18:02 - 26 Oct 2010    Post subject: Reply with quote
Well, tomorrow was a long time coming!
The first job I did was rectify the fact that the gear lever was 15 inches (430mm) from the footpeg. This is ok for trials when they never change gear but no good for what I wanted. The easiest thing to do would have been to move the rests to where Ariel intended them to be but I like them well back as it keeps your weight well over the front wheel, ideal for freak hillclimbing.
After much head scratching I decided to use the kickstart shaft as the shaft for the gear lever as well by extending it with a shoulder bolt.
PostPosted: 18:07 - 26 Oct 2010    Post subject: Reply with quote
Meant to rate it as cool, but was laughing at a film I'm watching Doh!
Very cool Laughing
CHR15
PostPosted: 18:12 - 26 Oct 2010    Post subject: Reply with quote
have you considered stratigicly weakening the new gear changer? it looks quite strong, and if that doesnt fail, i guess it will remove your kickstart mechanism?
Ariel Badger
Next job was to pull the top end down and see what lived within. First thing wrong was the valve pushrods, They should be made of aluminium tube with steel ends. What I had was one made out of solid aluminium bar and one from steel tube. I quick trip to my metal supplier and I had some ali tube that was almost the right side, half an hour in the lathe and they were just right.
Frost
PostPosted: 18:21 - 26 Oct 2010    Post subject: Reply with quote
Cool as Penguin piss.
MaybeGuy
PostPosted: 18:29 - 26 Oct 2010    Post subject: Reply with quote
aren't you going to harden or sleeve the end of the pushrod?
Even building up with weld then facing it off would make it much harder.
Also, tbh the rearset looks a bit bodge even by my standards. Maybe turn a peg down and press it in or something? It looks like a door handle
Ariel Badger
PostPosted: 19:01 - 26 Oct 2010    Post subject: Reply with quote
Once I had the head off I could at least measure the piston and order a high compression scrambler job from Draganfly Motorcycles ( although I am now on the case of a even higher ratio piston that I may buy if it looks good).
I also have (on long term load a Scrambler cam and followers (Std on L in picture).
Ariel Badger
PostPosted: 19:05 - 26 Oct 2010    Post subject: Reply with quote
As I said there are steel ends to the rods, ball one end, cup the other. They were removed when I took the photo.
One piece lever is stronger than two piece. It may look crude but it works superbly. It is fitted with a phos bronze bush to run smooth on the shaft. It does stick out further than I would do for a road bike but when I am being battered on the big hill I need to be sure of my gearchanges and I am not going to miss that door handle. It is no bodge, it just never got polished.
Ariel Badger
PostPosted: 19:55 - 26 Oct 2010    Post subject: Reply with quote
New cam and rods fitted into the engine. I always lighten the cam gear, it is my little sig in a motor.
Ariel Badger
PostPosted: 19:59 - 26 Oct 2010    Post subject: Reply with quote
When I was working on the box I droped a little ball that the clutch rod bears on into the box itself and had to strip it to recover my ball.
This is how to position an Ariel to tear the box down.
tvchimp
PostPosted: 21:20 - 26 Oct 2010    Post subject: Reply with quote
There isn't many words able to describe the awesomeness of this.. Laughing
Quick question, how good are ariels for day-to-day biking? Obviously you have them for mainly trials and hill-climbing, but they look 'the sex' and I wouldn't mind one to potter about on.. Cool
Ariel Badger
PostPosted: 22:13 - 26 Oct 2010    Post subject: Reply with quote
I used a 1939 girder forked 350 as everyday transport for about 6 years. I rode her to work, rallies and trialled her at weekends no matter what the weather. No problems apart from blowing two engines from serious abuse and a fire in Shropshire.
The Ariel club annual rally was in Germany this year, most of those attending rode there.
ajbsmirnoff
PostPosted: 22:54 - 26 Oct 2010    Post subject: Reply with quote
I appear to have stumbled unto some homemade hardcore bike/engineering porn.
Nice work.
Ariel Badger
PostPosted: 09:07 - 27 Oct 2010    Post subject: Reply with quote
Nice work.
Thanks! Although this was my Porno build
Ariel Badger
PostPosted: 18:56 - 27 Oct 2010    Post subject: Reply with quote
Once I had all the work sorted I cleaned the bash plate and exhaust while they were off the bike. The last couple of jobs were to put wider bars on and do a bit of work on the ignition. The bike was originally fitted with a Lucas wader magneto ( long gone) but was when I bought it running electronic ignition in a thing that looked like a BTH mag through a coil under the tank. The penultimate owner was a woman who could not start the bike on a mag (God knows why not, she was on the large side.) so her dotting husband fitted the very expensive electronics. It was her now ex husband I bought the bike from and part of the deal was he wanted the ignition thing back and supplied me with a beautiful BTH racing mag as a replacement. Changing over only took an hour of so and I poured a couple of pints of petrol in the tank and kicked her over.
In fact I kicked her over quite a bit and nothing happened. I took the plug-cap off and sent a 1/4 inch spark flying to the frame so then I connected the lead straight to the plug and kicked a lot. Then it occurred to me that the electronic thingy could handle a suppressed plug. A quick Google on the spark plug conformed it did have a built in resistor so I found an old pink Lodge and screwed it in second kick she fired up.
Old bikes need old plugs.
Handsome
PostPosted: 19:34 - 27 Oct 2010    Post subject: Reply with quote
Is this the one that was in the back of the van with no lump in it ?...
D O G
PostPosted: 19:49 - 27 Oct 2010    Post subject: Reply with quote
Are those holes equally spaced? The top two look closer together - or am I just seeing things?
Ariel Badger
PostPosted: 20:11 - 27 Oct 2010    Post subject: Reply with quote
No mate, that was the Badger, she is back up and running on a new crankshaft.
As for the spacing of the holes Embarassed
The last post was made 16 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.4 - MySQL Queries: 13 - Page Size: 136.7 Kb
