Rxs 100 Electrics
xpetop
PostPosted: 14:50 - 09 Aug 2010    Post subject: Rxs 100 Electrics Reply with quote
Hi guys
I've got a RXS100 which has been stood for a while.
when i try the horn / indicators whilst the engine is not running they are pretty poor, When the engine is running they work fine.
I have cleaned as many connections as possible including the switch gear.
New horn fitted.
New battery fitted.
Awaiting new indicators.
Any advice greatly recieved
Alan
27cows
PostPosted: 16:10 - 09 Aug 2010    Post subject: Reply with quote
That's 6 volt electrics Confused Although it does sound like you might have a poor earth connection. Probably already done so, but if not make sure the two main earth points are sound. It's common for rust or corrosion to make the already poor electrics even worse.
xpetop
PostPosted: 09:50 - 10 Aug 2010    Post subject: Reply with quote
I'll double check.
It looks like someone has messed with the earth in the back indicators so i'll run a earth direct to the battery to try and discount this as a problem.
Regards Alan
xpetop
PostPosted: 15:01 - 22 Aug 2010    Post subject: Reply with quote
Well new indicators turned up but were fitted with capless bulbs Shocked .
So does anyone know where i can get some 6Volt 21Watt capless bulbs?
Instead i fitted new bulbs to the old indicators and put a new earth onto each of them and connected to a clean earth on the frame. All working
The horn was fixed by turning the little screw at the back which was temperamental but now works.
Alan
loudmatter
PostPosted: 22:59 - 22 Aug 2010    Post subject: Reply with quote
i got my new indicator bulbs from www.wemoto.com/bikes/Yamaha/RXS_100/83-85/ have a look on there.
whilst on the subject my indicators dont work when engine running or not could this be a earth problem or a loose wire behind the head light?
LOUDMATTER
27cows
PostPosted: 08:15 - 23 Aug 2010    Post subject: Reply with quote
More likely the contacts in the indicator switch are corroded. Very common problem. You can carefully dismantle the switch and clean the contacts with a bit of wet and dry paper, then roughen them with the tip of a stanley knife. That's what I do and it seems to work.
Any indicators with capless bulbs aren't meant for the RXS. Standard items, both black backed and the earlier chrome ones, are pretty easy to come by though.
The last post was made 16 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 14 - Page Size: 47.4 Kb
