ns125r sprocket help
maveick1983
PostPosted: 12:09 - 16 Sep 2005    Post subject: ns125r sprocket help Reply with quote
id like to get some sprokets from https://shop.wemoto.com/index.dyn?oid=1913029
im not sure what the difference is could anyone help?
i had some great help about a caliper from keith and have now got it on its way from a breakers thanks..
i have a choice of
1)Sprocket Pattern Front Plus 1 Tooth
2)Sprocket Pattern Front Less 1 Tooth
3)Sprocket Pattern Front
4)Sprocket Pattern Rear Plus 2 Teeth
5)Sprocket Pattern Rear Less 2 Teeth
6)Sprocket Pattern Rear Less 1 Tooth
7)Sprocket Pattern Rear
OreoXX
PostPosted: 12:18 - 16 Sep 2005    Post subject: Reply with quote
By adding tooths on the front sprocket, you will gain top speed, but lose acceleration.
By adding tooths on the rear sprocket, you will lost top speed, but gain acceleration.
I'm not too familiar with the NS125R, but on the NSR125, the standard sprockets are 13x35, so I changed to 14x36, which works great!
By the way, thanks alains for the sprocket advice, the bike gained a little top speed and the acceleration is still great!
Marci
PostPosted: 12:37 - 16 Sep 2005    Post subject: Reply with quote
Well, give the alternates too...
by adding on the front / taking away on the back...
by adding on the back / taking away on the front...
1 tooth on front sprocket = 3 teeth on rear sprocket on the NS125R (I think)
So if you add 1 tooth to front sprocket it's equivalent of going down 3 teeth on the back...
Tend to get it nailed as close as possible by changing front sprocket, then go up or down 1 on the back to fine tune it...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
alains
PostPosted: 13:18 - 16 Sep 2005    Post subject: Reply with quote
to be precise 1 tooth front= 2 1/2 rear
it's easy to calculate :
example 13x35 gives you 35:13=2.692
............. 14x35 ............... 35:14=2.5
increase of 0.192 which is about 7.1% of top speed
.............. 13x34................ 34:13=2.615
increase of 0.077 which is about 2.9 %
PostPosted: 14:03 - 16 Sep 2005    Post subject: Reply with quote
Depending on where you are riding it may be worth sticking with standard gearing.
While aiming for a higher top speed might be OK, and might well make the engine more relaxed on a long high speed journey, your bike might also not have the power to pull the higher gearing. Standard NS125s definatly had problems with this even on the stock gearing. Also round town it will make moving off slightly more tricky. Probably not a major problem, until you try doing a hill start with a pillion.
Likewise lowering the gearing for better acceleration might be great around town but a total nightmare for a long journey on a motorway.
I would (for now) stick with standard gearing and see how the bike feels. Sprockets are not expensive so you could consider buying a couple of extra ones at the same time to have a play.
Remember that changing the sizes of the sprockets may affect the length of the chain you need.
Marci
PostPosted: 14:43 - 16 Sep 2005    Post subject: Reply with quote
Aye, I've found no need to change gearing whatosever with mine and it suits for both town and motorway...
There is a gap of 4 years, 345 days between these two posts...
Jorge
PostPosted: 15:24 - 26 Aug 2010    Post subject: Reply with quote
although im not yet 17...... Laughing i just had to take mines a spin ! i live in mallaig so the police go home at 12am Laughing . so any way, i took it a spin and got 100mph out of it FLAT OUT !! i just changed the chain and sprokets before hand and they are standard at 13 on the front and 35 on the back.
Thats fast enough for me i would hate for the engine to seize at that speed ! Razz Twisted Evil
HONDA NS125R-K
PostPosted: 15:35 - 26 Aug 2010    Post subject: Reply with quote
Welcome to the world of inaccurate speedos. NS125 will be doing about 84mph at 10000rpm on 13:35 gearing (so a real 100 would need about 12000rpm, and not a hope it would get to that in top, with peak torque being at about 8000rpm on a derestricted one).
Jorge
PostPosted: 15:38 - 26 Aug 2010    Post subject: Reply with quote
yep i totally agree! to be honest i didnt acctually beleive the speedo as i have heard that they are as good as an ash tray on a motorbike. hahaha Laughing
HONDA NS125R-K
The last post was made 16 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 14 - Page Size: 63.92 Kb
