Bodgeit and scarper!
Asharin
PostPosted: 17:50 - 27 Aug 2010    Post subject: Bodgeit and scarper! Reply with quote
Some time ago I had a wire from the ignition split and snap. We'd temporarily bodged it with a candybar connector and it's held til yesterday morning.
Sadly due to the wire having very little play the movement of the handlebars over time has caused the wire to break where it was held in the connector. It did this when i was just about to go out to collect my mums prescription and then take it up to her house.
So I wheeled it back to my house (was only 2 mins walk) and set to. went into the pile of crap in the shed (a pile of bits and pieces of machinery and electronics that no longer work) and grabbed a power cord. Stripped the ends, and using 2 candybar connectors I added the short length of wire to the existing ignition wire. Added electrical tape and jobs a good 'un.
I may do a proper job sometime but until then this will do Very Happy
Photo of the bodge, see if you can spot it..it's very well hidden! Very Happy
https://i285.photobucket.com/albums/ll68/asmodeanv/Bike/P1020091.jpg
-Savage-
PostPosted: 18:16 - 27 Aug 2010    Post subject: Re: Bodgeit and scarper! Reply with quote
What are
asharin wrote:
candybar connectors
Confused
Odie
PostPosted: 18:19 - 27 Aug 2010    Post subject: Reply with quote
chocolate blocks, bloody house hold wiring connector type thing, should never be used on a bike, hope it dont go at night on a back road.
get it sorted, your only putting off the inevetable.
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
Asharin
PostPosted: 18:26 - 27 Aug 2010    Post subject: Reply with quote
Yeah chocolate blocks Razz Was the only connectors I had handy. What type would you recommend?
Digit
PostPosted: 18:33 - 27 Aug 2010    Post subject: Reply with quote
Solder and heat shrink tubing!
Roy.
Happy daze!
ian789
Milk Chocolate Cool
Asharin
PostPosted: 18:35 - 27 Aug 2010    Post subject: Reply with quote
Roy.
Obvious really..I'd have to buy a soldering iron first Razz
Digit
PostPosted: 18:41 - 27 Aug 2010    Post subject: Reply with quote
Make sure that the iron is 75 watts or larger, the 25 watt ones won't do harness repairs.
Roy.
Happy daze!
PostPosted: 18:45 - 27 Aug 2010    Post subject: Reply with quote
asharin wrote:
Roy.
Camp stove + 6" nail + molegrips = soldering iron.
Digit
PostPosted: 18:54 - 27 Aug 2010    Post subject: Reply with quote
Only for the desperate! Laughing
Roy.
Happy daze!
Asharin
PostPosted: 19:07 - 27 Aug 2010    Post subject: Reply with quote
I think I'll buy one..it'll be useful for other things too.
Noxious89123
PostPosted: 20:26 - 27 Aug 2010    Post subject: Reply with quote
Can you solder though?
Asharin
PostPosted: 22:05 - 27 Aug 2010    Post subject: Reply with quote
Haven't soldered since I was 22 or so but I am sure I can manage..that's only 13 years ago.
Besides, it's only soldering 2 wires together, not exactly rocket science! Don't think I'd be up to soldering any stuff like circuit boards though Razz
Asharin
PostPosted: 04:27 - 30 Aug 2010    Post subject: Reply with quote
New proper cable here ready.
Heat shrink tubing here ready.
Soldering iron...on order, hopefully should arrive Tues/Weds hopefully the bodge fix will last until then!
I may not care for the appearance of my bike much but even for me that bodge is ugly Very Happy
-Savage-
PostPosted: 08:52 - 30 Aug 2010    Post subject: Reply with quote
Shocked
skatefreak
PostPosted: 09:38 - 30 Aug 2010    Post subject: Reply with quote
Soldering iron is great,
crack yr fairing, give it a stab,
potting posies, poke holes in the pots,
wanna get high, use it as part of a vaporiser,
burn wood....?
-Jvr
Blue_SV650S
PostPosted: 10:15 - 30 Aug 2010    Post subject: Reply with quote
Why not?
There is nothing wrong with a choc-block .... if you can do household stuff with them (240v 13A AC mains), why should one squirm at the thought of some piddly 12v DC system!?!? Thinking
Sure, solder and heat shrink is the way forward, but as a temporary measure, I see this is fine .... arguably much better than the standard 'twist and tape' which is normally employed in such situations!?!?! Razz
pits
PostPosted: 11:32 - 30 Aug 2010    Post subject: Reply with quote
Why not?
For me it isn't that it won't handle the power, as it will do that happily, it is the amount the wiring can shift around on a bike as opposed to a house where it is fixed.
Vibration and bumps will loosen the connectors off slightly, queue the wire falling out, not something I would use on a bike either
virus
PostPosted: 12:07 - 30 Aug 2010    Post subject: Reply with quote
Roy.
what a load of crap, Ive built wiring looms with a 15w iron with no failiures over the years.
cheers
John
own: 81 xs1100g...
Blue_SV650S
PostPosted: 12:11 - 30 Aug 2010    Post subject: Reply with quote
But as long as it is all taped up nicely, I really can't even see that is a problem as the wire ends aren't really taking any load ....
Digit
PostPosted: 12:14 - 30 Aug 2010    Post subject: Reply with quote
Okay John, for your benefit I'll rephrase that, a 75 watt iron is better that a 25 watt iron on heavy wires, ok?
Roy.
Happy daze!
virus
PostPosted: 12:39 - 30 Aug 2010    Post subject: Reply with quote
replace 'better' with 'quicker' and I'll agree. Wink Thumbs Up
John
own: 81 xs1100g...
finpos
PostPosted: 13:02 - 30 Aug 2010    Post subject: Reply with quote
chocolate blocks - fine short term, long-term they don't provide any strain relief and the metal bits rot in the damp, all of which makes you fume when you lift the seat off your "new" bike and find 50 of them in there Smile
f.
Raffles
PostPosted: 14:20 - 30 Aug 2010    Post subject: Reply with quote
We call them domino block connectors around these parts (can't for the life of me think why Wink ). Anyways they are, as previously pointed out, crap and totally unsuitable for automotive usage. Often, whilst tightening the connector screws, you will sever a number of strands of wire and whats left will quickly corrode due to water ingress.
The last post was made 16 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 126.73 Kb
