ER5 Coolant.
Willson
PostPosted: 13:39 - 29 Sep 2010    Post subject: ER5 Coolant. Reply with quote
I open the radiator cap (under the tank), fill it up, and alas comes coolant leaking out of both sides of my engine block.
There are two what look like overflow holes in the side of my engine, and the coolant comes straight back out of there.
I am led to believe there I should be able to see the coolant when I take the radiator cap off, but I cannot.
Could I have a broken pipe? Or is it a thorough strip down job?
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
PostPosted: 13:57 - 29 Sep 2010    Post subject: Reply with quote
Those drain holes (small holes between the fake cooling vanes on either side) drain the sparkplug recesses.
So, coolant is leaking into your sparkplug recesses.
Have you had any work done on the engine recently (eg, tappets checked)? If the rocker cover has been removed for any reason, it necessitates removing two steel coolant pipes which pass down through the rocker cover first.
If you don't fit a brand new o-ring round the end of those pipes when you re-fit them, they will leak coolant into the sparkplug recess which in turn comes out of those drain holes.
In any case, if you remove the tank, it should be obvious where the coolant is coming from, there is a very small area it could be leaking from to land up in the sparkplug recess. It will be coming from around one of those two pipes, where the rubber hose joins those pipes or from a split in the rubber hose.
Yes, under normal circumstances, the radiator should be brim full.
The last post was made 15 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 32.57 Kb
