can't find neutral!
Jivehunny
PostPosted: 19:57 - 03 Oct 2010    Post subject: can't find neutral! Reply with quote
Hiya,
I am new here and a very new riider! I have been out on my bike twice now (it's a 125 Kymco Hipster) and I can't seem to find neutral when I pull up to stop. I find it easily when the ignition is on but the engine is not running. I have to use the the cut-out switch to turn off the engine as the key is by my left knee and I can't let go of the clutch to reach it. I then have to switch the ignition back on, select neutral and then switch it back off!! I sit for ages trying to find it but the gears are extremely stiff when the bike is not in motion. Is it me?? Any ideas?
Carvel
PostPosted: 20:03 - 03 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
maybe a oil change could help a little bit
This.
I couldnt find neutral on my rxs, changed the oil and it was fine.
Carl_steveo
PostPosted: 20:06 - 03 Oct 2010    Post subject: Reply with quote
Try the above or try blipping the throttle as you try to get into neutral. Little tip I got from Hadies on here and it works every time for me.
Current: Honda Nsr 125
Live: Sunderland
Jivehunny
PostPosted: 20:07 - 03 Oct 2010    Post subject: Reply with quote
I don't know! It has a new MOT- does that get picked up on an MOT? I am just reading up on how to maintain the bike too so I will check. I have only had the bike a couple of weeks and I bought it the day after it went through it's MOT and it had recently been serviced. ps Thanks for response!
Jivehunny
PostPosted: 20:10 - 03 Oct 2010    Post subject: Reply with quote
'Blipping' the throttle? What do you mean please?!
delvey91
PostPosted: 20:11 - 03 Oct 2010    Post subject: Reply with quote
On a few of the bikes ive had it was easier to knock it into neutral just before coming to a stop. Or try rocking the bike back and forwards slightly whist stopped and it should slip into neutral Smile
Skudd
PostPosted: 20:16 - 03 Oct 2010    Post subject: Reply with quote
Just blip the throttle a little bit, also it may be because you are too heavy footed. Practice helps too.
Martay
My chinese 125 was a slag to get N when idling standing still. As said, knock it into neutral just before you stop, or try the rocking method. When you get used to it, all will be fine.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
johnsmith222
If you mean putting it in neutral at traffic lights etc, then don't. There's no reason why you should and it avoids the hendon shuffle.
Jivehunny
PostPosted: 20:23 - 03 Oct 2010    Post subject: Reply with quote
Thanks- I will try said advice. I didn't mean at traffic light- just when arriving at destination but on studying the Practical Test it says that you should knock it into neutral if stopping for a longer time such as at 4 way traffic lights.
Carl_steveo
PostPosted: 20:28 - 03 Oct 2010    Post subject: Reply with quote
By blipping I mean give it a few revs, I don't mean like a hand full just a few revs. Obviously with the clutch in.
Live: Sunderland
woodsyshouse0...
PostPosted: 20:47 - 03 Oct 2010    Post subject: Reply with quote
try this, when you are at a standstill and very sure your in first gear, apply your front brake put your left foot up and press the gearlever and hold it down, slowly release the clutch lever till you feel the biting point, snap the clutch back in then lift the gearlever with your foot and hold again ,then slowly release the clutch lever to the biting point, then snap the clutch back in and gently tap the lever down into neutral......good luck
yen_powell
Sounds like a badly adjusted clutch cable. In neutral how much movement/free play is there at the ball end of your clutch lever before the cable starts to pull.
XT1200Z and a DR350 in bits
jimspeed
PostPosted: 20:49 - 03 Oct 2010    Post subject: Reply with quote
try adjusting the clutch cable a bit tighter as maybe its dragging a tiny bit and keeping load on the gears, my kwak was like that when i got it and the clutch also bit really early like as soon as you started to let it out away from the bars it would try to drive off.
oh and welcome to bcf Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Jivehunny
PostPosted: 21:07 - 03 Oct 2010    Post subject: Reply with quote
Jees! This riding lark is a lot harder than I thought!! I think I need to take time out to learn how to maintain the bike and how to adjust things for myself. Feel abit on my own as I don't know any other lady bikers! Forgive me if I need things explaining to me but I want/need to learn all this to fullfill my dream!
I don't know how much play in the clutch lever but I will go play with the bike after work tomorrow. Keep with me please guys and gals!
Skudd
PostPosted: 21:27 - 03 Oct 2010    Post subject: Reply with quote
Just how I felt when I started 27 years ago. I didn't have the t'internet at hand back then so learnt by some very bad bodges.
Just remember that no question is stupid ......... provided you have used some common sense first. Oh............ and you never stop learning. Thumbs Up
c_dug
PostPosted: 21:31 - 03 Oct 2010    Post subject: Reply with quote
For me if Neutral is being an arse I find it easiest to hold the brakes on and feed the clutch out a little bit, just until you feel the front of the bike dip a little, then bring the clutch back in and try for Neutral again.
This method has always worked for me.
Jivehunny
PostPosted: 21:43 - 03 Oct 2010    Post subject: Reply with quote
I must have felt like this when I learnt to drive 13 years ago! I tried feeding the clutch and still couldn't get it in! It will be trial and error using all these suggestions 'til I find one that works. I will let you know how I get on so thanking you all!
ps Passed my Theory on Thursday! Razz
swampy
PostPosted: 21:45 - 03 Oct 2010    Post subject: Reply with quote
Looking at your profile you're not too far from me... if you need a hand with things like adjusting the chain etc give me a yell if you wanna, might be able to help you out with bits and bobs like how to check oil etc Thumbs Up
yen_powell
PostPosted: 21:52 - 03 Oct 2010    Post subject: Reply with quote
If you look at your clutch lever you will see where it hinges on the handlebar the cable goes through a grooved tube with a larger round disc on one end. Those are one of the cable adjusters. The large disc is loosened so you can turn the tube either in or out of the clamp, which adjusts the cable length. https://faq.f650.com/FAQs/Photos/ClutchPhotos/ClutchLeverAdjust.jpg
Jivehunny
PostPosted: 21:59 - 03 Oct 2010    Post subject: Reply with quote
Oh- like on bicycle brake cables? The same sort of principle?
@ Swampy- thanks, might hold you to that!
yen_powell
PostPosted: 07:10 - 04 Oct 2010    Post subject: Reply with quote
Possibly, I don't do vehicles that give me wobbly legs and a wheeze. Shocked
If you're clutch lever has too much play in it then finding neutral at a standstill with the engine running becomes difficult. Also it can make putting it into first gear problematic. Ideally you want about 5-10mm 'sloppage' at the lever end.
Adjusting it properly also moves the bite point more towards the end of the lever movement, giving you more control when pulling away or wobbling about between a line of cones.
I've noticed on a lot of smaller bikes that the cable stretches from heat expansion when riding round town, so I adjust when the bike is at a decent running temperature.
Jivehunny
PostPosted: 07:56 - 04 Oct 2010    Post subject: Reply with quote
Me neither and I don't do spandex or lycra either! Laughing
My son has a BMX and I have had to maintain.
Great info thank you- more incentive to get out there and 'tinker'. shame I have to go to work.......
yen_powell
PostPosted: 08:25 - 04 Oct 2010    Post subject: Reply with quote
I've nearly lost my lunch a few times with some spandex lunchboxes wobbling about in cycle lanes on the A13. It's like a road accident, you know it's better not to stare but you can't help it.
The last post was made 15 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 129.74 Kb
