1993 (1992?) cbr600f - any information/reviews please
c_dug
PostPosted: 10:09 - 08 Oct 2010    Post subject: 1993 (1992?) cbr600f - any information/reviews please Reply with quote
Hi guys.
CBR600F on ebay. It says it's a 1993, but after some googleing it appears to be the older shape one, so I am guessing it's a late registered 1992 model.
What are these like?
Back wheel looks kind of small in the picture, does it use 17" wheels?
Usual bullet proof Honda-ness?
Anything else I need to know, before I go and see it.
Can't find a huge amount of info on Google for this shape.
Thanks
c_dug
c_dug
PostPosted: 10:14 - 08 Oct 2010    Post subject: Reply with quote
In fact, what would be even better would be if somebody could identify the year of this bike for me so I can look for the correct reviews and information:
https://i.ebayimg.com/18/!BzS5GU!BGk~$(KGrHqEOKnIEw8oQtmz5BMVbwitTPQ~~_3.JPG
Frost
PostPosted: 10:19 - 08 Oct 2010    Post subject: Reply with quote
They are reliable bikes, but at 17-18 years old even reliable bikes can have a huge list of problems. Provided it's cheap enough and looks in decent nick, i'd go for it.
DrDonnyBrago
The merkins call it the CBR600F2, 1991-1994.
Most info will be on yank sites so search for the F2 to get a review.
https://en.wikipedia.org/wiki/Honda_CBR600F2
DrDonnyBrago
PostPosted: 10:31 - 08 Oct 2010    Post subject: Reply with quote
Also, forgot to say that it is called the cbr600 FM in the UK Thumbs Up .
Serendipity
PostPosted: 10:33 - 08 Oct 2010    Post subject: Reply with quote
That picture you posted is that same era of 1991-1994. That’s from when the CBR6 was undisputed king of the 600s. Awesome bikes. The shape of the side fairing and inspection panel changed for 1995, so that one you pictured is before that.
I’ve got a 1994 CBR600FR and covered loads of miles with minimal problems.
The headers will have long since rotted away, so probably already been replaced. Carb inlet rubbers harden and perish. I had the seals let go in the oil cooler forcing oil into the coolant. The electrics are typical Honda in that the reg/recs can overheat and die. If you do lots of hot, slow urban commuting the insulation breaks down on the stator and you get charging problems.
2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
c_dug
PostPosted: 10:43 - 08 Oct 2010    Post subject: Reply with quote
Sounds promising, I think I'll go check it out tonight Thumbs Up
Any particular weak points to look out for?
Chalky.
PostPosted: 11:20 - 08 Oct 2010    Post subject: Reply with quote
I've got a '95, think it is an F2 or F3.
Headstock bearings can be a problem, really you want stainless downpipes cos they go like cheese.
The the usual possibilities of crash damage, chain and sprockets, tight gearbox etc.
supZ
PostPosted: 13:12 - 08 Oct 2010    Post subject: Reply with quote
its a honda so rattle on startup indicates CCT problems (not a big deal, quick fix but you can get some cash knocked off for it) and check to make sure the reg/rec is working.. i.e. lights dont change brightness too much when revving etc.. and it starts strongly
and as above.. check for crash dmg etc.. its a well built bike so if its been looked after you've got nothing to worry about.
great little things Smile
CBR954RR - Daily toy
CBR600RR - Trackbike
mad4it028
PostPosted: 14:17 - 08 Oct 2010    Post subject: Reply with quote
there good solid bikes hold there price well i had one with 50k on the clocks and still ran perfect
cam chain tensioners are there weekness and the fact there an expensive bike for there age for not much more money you can normally get a zx6r or such like
c_dug
PostPosted: 14:26 - 08 Oct 2010    Post subject: Reply with quote
Did they come with clip ons as standard?
The ad says it has clip ons fitted, can't really tell from the pictures.
Clip ons + end can = chance that it was a track bike Question
Or am I being paranoid about using my money Laughing
PostPosted: 14:29 - 08 Oct 2010    Post subject: Reply with quote
All sportsbikes wear clip ons...? As long as it doesn't say "Renthal clip ons" or something then it'll be fine.
c_dug
PostPosted: 14:31 - 08 Oct 2010    Post subject: Reply with quote
My ZZR didn't.
Only questioning it since it says it in the extras bit.
Ah well, just waiting on a reply from the guy and then I'll go check it out.
Thanks for all the info Thumbs Up
lihp
PostPosted: 21:13 - 08 Oct 2010    Post subject: Reply with quote
I have the same model of bike, which I use everyday, but is 1992 registered, with 44k miles.
Starts and runs perfect, just needed a little tightening. Just ordered a new CamChain Tensioner for it, and it just needed new tyres.
Mine had charging problems, but wasn't the Regulator, it was brittle 18 year old wiring. Check the connectors, I've had to replace the headlight one, and also had to rewire the connections between alternator and R/R infront of the battery.
Other than that, mine has had no problems at all, and is a great bike to ride, they do have clip ons as standard, but are clipped on ABOVE the top yoke not below.
yanto
PostPosted: 21:26 - 08 Oct 2010    Post subject: Reply with quote
c_dug wrote:
My ZZR didn't.
zzr is a sports tourer yzf gsxr cbr zxr all have clip ons maybe some exceptions to this rule
th only problem i had was cct but got a manual one from ape never had the problem again
lihp
PostPosted: 21:45 - 08 Oct 2010    Post subject: Reply with quote
I thought about getting a manual one, but may cause more harm than good in the long run.
At higher mileages, if it's rattling, even with a good hydraulic tensioner, there may be other issues, such as a stretched cam chain, and bad guides.
Using a manual one, may make the noise go away, until the chain finally gives way. If it still rattles after a new tensioner (Which is cheaper than the manual one too), then inspect the condition of the camchain and guides, as they can all be changed with the engine still in the frame.
PostPosted: 21:55 - 08 Oct 2010    Post subject: Reply with quote
c_dug wrote:
My ZZR didn't.
All ZZR's come with Clip ons as standard as far as I'm aware.
c_dug
PostPosted: 23:55 - 08 Oct 2010    Post subject: Reply with quote
The 600 never came with clip ons, I can say this for definite Thumbs Up
Bought the CBR anyway Thumbs Up
Thanks for the advice everybody.
c_dug
lihp
PostPosted: 01:32 - 09 Oct 2010    Post subject: Reply with quote
c_dug
100% the CBR600F came with clip ons, but mounted above the yoke not below.
Download the Honda service manual and have a look Wink
c_dug
PostPosted: 08:28 - 09 Oct 2010    Post subject: Reply with quote
I meant the ZZR600 Laughing
arry
PostPosted: 09:01 - 09 Oct 2010    Post subject: Reply with quote
c_dug
Good choice Thumbs Up
Still well pleased with mine Smile
PostPosted: 09:13 - 09 Oct 2010    Post subject: Reply with quote
Looking at images on the 'net, all of the ZZR600 ones I can find (which aren't american ZX6R's) have clip on handlebars.
Basically, if its not one long bar that is clamped to the yoke, then they are clip ons.
c_dug
PostPosted: 09:15 - 09 Oct 2010    Post subject: Reply with quote
Fair enough, I was only counting this type:
https://www.ca-cycleworks.com/shop/catalog/ducati/img/50mm_clip_ons_speedymoto.jpg
PostPosted: 09:19 - 09 Oct 2010    Post subject: Reply with quote
c_dug wrote:
They aren't too different to what you see on a ZZR, its just on a lot of bikes they go below the yoke, whilst on the ZZR they go on top of the yoke and perhaps have some rise in them too.
When the ad says 'clip on handlebars' I'd expect that to be a standard thing...
The last post was made 15 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.97 - MySQL Queries: 14 - Page Size: 126.49 Kb
