honda cg keeps dying
WULFSTAN
PostPosted: 14:44 - 08 Oct 2010    Post subject: honda cg keeps dying Reply with quote
alright lads hope u can help when am riding my bike after about a mile it keeps dying on me once it stops it starts again after a few kicks then dies again after a other mile or so ive checked my spark plug. cleaned carb,charged oil and checked air filter anyone know what the problem is ? thanks
pepperami
PostPosted: 15:13 - 08 Oct 2010    Post subject: Reply with quote
Is the fuel line partially blocked?
Is your fuel tank cap blocked or partly blocked
Are your points worn?, or is it a non-points model?
Is the coil breaking down under load? or as it warms up?
does you plug cap have a resistor in it? is that playing up and interfering with sparks?.
just a few ideas? possibly? maybe?
WULFSTAN
PostPosted: 15:17 - 08 Oct 2010    Post subject: Reply with quote
thanks mate will check the things you have said
Frost
PostPosted: 15:20 - 08 Oct 2010    Post subject: Reply with quote
Sounds like fuel to me.
WULFSTAN
PostPosted: 15:23 - 08 Oct 2010    Post subject: Reply with quote
do you mean bad fuel? ive put more fuel in the bike since this problem has started now that i think about it the problem started after putting a fiver in it
Frost
PostPosted: 16:05 - 08 Oct 2010    Post subject: Reply with quote
Fuel goes off after a while. Also water can get into it making it run like crap. Dirt and water in the bottom of the tank can sometimes get sucked into the system when the bike runs low for the first time in ages. Follow the fuel pipe and see if you can find a filter that might need cleaning.
WULFSTAN
PostPosted: 13:46 - 09 Oct 2010    Post subject: Reply with quote
thanks for the answers turned out to be bad fuel from shell sorted now
The last post was made 15 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 14 - Page Size: 51.05 Kb
