| killa |
 killa Won't Shut Up
 Posted: 08:42 - 18 Jul 2011 Post subject: 1979 GP100 carb issue |
I was taking a look over Luthians bike at the weekend and come across something I’m not sure of.
Basically when taking off the carb cover petrol pissed out all over the floor as it had been leaking inside the casing.
Now this is a contained carb which I’m not used to, so any leaks or anything usually just goes on the floor, as over flow pipes drop through the frame (like on my old DTR for example)
If you take a look at the photo attached, i know what everything is but I don’t know why the over flow pipes are shoved down into that hole.
Both pipes are shown to be in there, so firstly, where the F does that go?!
Secondly it isn’t the larger diameter pipe (that comes from the top of the carb) but the smaller black one that is leaking (from the float bowl).
It only leaks when then bike has been running and is then switched off. Not whilst running.
I have set the pilot jet and throttle idle properly to the Haynes, the bike runs absolutely fine.
Cheers  ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| Blau Zedong |
 Blau Zedong Banned
| cb1rocket |
 cb1rocket World Chat Champion
| cb1rocket |
| garth |
 garth World Chat Champion
| killa |
 killa Won't Shut Up
 Posted: 13:43 - 18 Jul 2011 Post subject: |
Thanks guys, i think it might be the float valve.
Ill strip this when i got time.
What gasket can i use to replace the one on the carb cover?
Also, would i need a gasket/sealent for the carb manifold into engine casing? ____________________ Cleverly disguised as a responsible adult.
| Blau Zedong |
 Blau Zedong Banned
| chris-red |
The last post was made 15 years, 80 days ago. Instead of replying here, would creating a new thread be more useful? |
