96 GPX600R Carb question
hornetmike
PostPosted: 23:09 - 18 Nov 2010    Post subject: 96 GPX600R Carb question Reply with quote
Just stripped,cleaned, changed a couple of float needles in my carbs. But now when you turn the bike over it runs a little, and fuel is leaking out of the air cleaner side of the carbs.
Its quite a lot of fuel and it doesn't stop when the engine is turned off. Could it be a faulty vac tap, or is it more likely something wrong with floats?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Casper
PostPosted: 23:38 - 18 Nov 2010    Post subject: Reply with quote
Make sure the fuel tap is on or reserve and not prime. Might be diaphragms or floats set to high.
finpos
PostPosted: 00:17 - 19 Nov 2010    Post subject: Reply with quote
Will be both - obv. the fuel is leaking past the vacuum tap and then leaking past the float valves. If I remember right you can't connect the vacuum tube and fuel lines up wrongly on those bikes, so that eliminates that particular howler.
f.
Casper
PostPosted: 10:19 - 19 Nov 2010    Post subject: Reply with quote
Have a look at this llink and scroll down to Running & Tuning Problems. The first post is a strip down and clean GPX carbs with pics.
https://www.kawasaki-rider.co.uk/forum/index.html
The last post was made 15 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.84 - MySQL Queries: 14 - Page Size: 38.59 Kb
