| T0MMY |
 T0MMY World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Suntan Sid |
 Suntan Sid World Chat Champion
| neatbik |
 neatbik World Chat Champion
| chris-red |
 Posted: 17:16 - 15 Dec 2010 Post subject: |
I had the same sort of thing I tightened the headstock 1/8th of a turn and it went away
It only happened under braking ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| T0MMY |
| chris-red |
| T0MMY |
| T0MMY |
 Posted: 11:57 - 17 Dec 2010 Post subject: |
Ok, had a bit of time today at work to look at the bike. Seems I was wrong about it being internal to the forks; it only makes the noise when the front brake is on and I bounce the forks. If I bounce them with it off then they're fine which makes me think headset bearings or front brake. The caliper bolts are tight and the disc has no play in it. The caliper does move a bit when you wobble it by hand but then I seem to recall that's normal (amazing that I'm not sure after 14 years of motorbikes ) as the slider pins have a bit of play in them?
As for the headset bearings I can't feel any play in them with the front wheel off the floor and I can't produce the clunk by pushing and pulling on the forks.
Any of this shed any more light on the problem? |
| chris-red |
| T0MMY |
| T0MMY |
 Posted: 15:00 - 17 Dec 2010 Post subject: |
Ok, did some more playing over my lunch break...
With the back brake on there is no clonk whether or not the front brake is on so it's the forwards and backwards motion that causes it, not the telescoping up and down of the forks.
On that basis, this could still be front brake, headset or something inside the forks really couldn't it
| chris-red |
| T0MMY |
 Posted: 15:46 - 17 Dec 2010 Post subject: |
I'm inclined to agree with you  |
| neil. |
 neil. World Chat Champion
The last post was made 15 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
