tt600 radiator cap removel
f1wade
PostPosted: 18:28 - 19 Dec 2010    Post subject: tt600 radiator cap removel Reply with quote
hi this may be a stupid question, but on my triumph tt600 03, i can turn my rad cap 90 degrees and its then loose but the cap will not come off the radiator.
is there a special way to remove it or is it not suppose to come off? if so how can i get it off, or do a full coolant change?
thanks in advance
chris
salty21
PostPosted: 18:35 - 19 Dec 2010    Post subject: Reply with quote
push it down and turn is some more, i think 90 degrees just gets you to the pressure release point if its like normal caps
mr.kris
PostPosted: 18:36 - 19 Dec 2010    Post subject: Reply with quote
there are little tabs push it down to get past them! you can normaly see them if you look closely
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
The last post was made 15 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.08 - MySQL Queries: 14 - Page Size: 36.14 Kb
