Changing Gears ....
daxo
PostPosted: 19:57 - 08 Jan 2011    Post subject: Changing Gears .... Reply with quote
I was just wondering in you can change gears without pressing the clutch...I saw a video on youtube that says that wouldnt damage the bike, is it true?
I'm new in geared bikes and its kinda long to go from 1st to 2nd when you want to leave the traffic light quick.
and before I mess up my bike I would like know the true (after all its a 125cc and I know It cant be that quick )
weasley
PostPosted: 20:15 - 08 Jan 2011    Post subject: Reply with quote
Short answer - yes you can.
Long answer - yes you can but you have to be aware of how it all works to make sure you do it right so you won't do any damage. When you pull the clutch you are releasing any driven torque through the gearbox, thus allowing you to make a shift. You can replicate this by simply easing off the throttle - if you are on a neutral throttle then there is no drive torque going through the gearbox and you can make the shift. The issue becomes that when you engage the next gear your engine revs and road speed no longer match, so you have to either be brutal or be sympathetic and let the engine revs drop a little to be kind (assuming changing up).
I commonly shift without the clutch, either when I'm in lazy, low speed touring mode, or when in full-on acceleration mode. In lazy mode I'll sometimes down-shift without the clutch too.
Having said that, I tend not to do 1st to 2nd clutchlessly as it's quite a clunk with the Yamaha and you have to go through neutral so can mess it up easily.
Glenben92
PostPosted: 20:33 - 08 Jan 2011    Post subject: Reply with quote
As above, it's doable and shouldn't cause damage in most circumstances, but it's not adviseable from 1st to 2nd
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Louise
PostPosted: 23:07 - 08 Jan 2011    Post subject: Reply with quote
have done before.
Up a gear, but never down for me.
Smile
Sam_Y_93
PostPosted: 00:00 - 09 Jan 2011    Post subject: Reply with quote
Up shifts are ok, and if done correctly wont damage the bike. Down shifts supposedly damage the gearbox so wouldn't do that. Also wouldn't clutchless shift between first and second as you go through neutral so might be clunky.
PostPosted: 09:03 - 09 Jan 2011    Post subject: Reply with quote
As everyone else has said. Shifting up can be done but down isnt recomended.
But I use a clutch all the time simply for the reason that the bike was supplied one for a reason. Thumbs Up
gearboxkart
PostPosted: 03:31 - 12 Jan 2011    Post subject: Reply with quote
bike is supplied with 1 so you can pull away and stop without stalling Wink
very very rarely used the clutch on my bikes over 30 odd year, just put a bit of pressure on the gearchange off the gas and in she goes, you will get to the point where your gearchanges are just a matter of off the gas for a split second and powering upto the next change, practice Very Happy
Paxovasa
PostPosted: 10:51 - 12 Jan 2011    Post subject: Reply with quote
I have been known to do both up and down clutchless changes, It is only going from neutral into first that you need to use the clutch Thumbs Up
The Blackbaron
PostPosted: 15:13 - 17 Jan 2011    Post subject: Reply with quote
Agreed with all posts,
I've done it a few times though I will not recommend 1 to 2 as it almost threw me off (I have a V twin engine)
But 3 onwards, is quite smooth, and barely any difference between clutching and none... I haven't noticed any damage nor does it feel different.
Either way I think the clutch lever is there for a reason and I think we should use it.
John karner This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 15 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 65.86 Kb
