Moped accelaration problems.
grantp
PostPosted: 20:11 - 29 Dec 2010    Post subject: Moped accelaration problems. Reply with quote
I have a yamaha neos 49cc - de-restricted and got a technigas(?) race pipe on it.
The accelaration is fine up to 30mph but if i release the throttle and then re-apply it, it takes literally forever to go any faster and it can do 45mph (only sometimes though, if i full throttle from standstill.) as I've had it to that on a private road.
I know it's not going to be the fastest moped on the road but it's quite scary on roundabouts when you have no power.
No comments about being a chavvy pedboi or how it's never going to be fast. Just looking for help with my moped.
Livefast123
PostPosted: 20:16 - 29 Dec 2010    Post subject: Reply with quote
See the Aprilia Rally thread........have you re-jetted the carb to account for your modifications or changed the rollers to match the powerband of the exhaust??
Take your sparkplug out and check the colour as your engine is probably on death row Thumbs Up
Current ride - Yamaha MT-07
TanacoiusD This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
grantp
PostPosted: 20:20 - 29 Dec 2010    Post subject: Reply with quote
replaced the spark plug yesterday for a ngk one and filled it up with oil as it was running low, i used castrol 2t part-synthetic.
grantp
PostPosted: 20:38 - 29 Dec 2010    Post subject: Reply with quote
rob yarrr wrote:
a mate had one and all he could get was 45/50 and his was ment to have a 70cc kit on
i've been told it might be my rollers, as the standard ones are 6.5g, after searching on the internet, it seems i have to replace the rollers for lighter ones..does this sound right?
stonesie
PostPosted: 21:19 - 29 Dec 2010    Post subject: Reply with quote
TanacoiusD wrote:
Power band of exhaust ..... Confused Confused
Oh yes, the tuned length of a 2 stroke exhaust changes both the position (where in the rev range) and size (how long it lasts) of the power band.
https://www.vespamaintenance.com/engine/primer/twostrokeact.gif
In this you can see the pulse heading back up the exhaust to ram any fresh charge that has started heading down the exhaust back into the cylinder, the more you cram in the bigger the bang. Altering the exhaust changes where in the rev range this effect is at its best.
Livefast123
PostPosted: 21:53 - 29 Dec 2010    Post subject: Reply with quote
Email technigas and see if they can recommend a roller weight for you. If you're tuning a 50 i'd use the best 2 stroke oil you can afford.
Some exhausts make the power highter up in the rev range and therefore require lighter rollers and some lower down which require heavier ones.
Your jetting in the carb may still be out, check out the Rally 50 thread which explains how to do a plug chop. Thumbs Up
Have you searched any Ped forums for somebody that may have done it before you.
Livefast123
PostPosted: 22:00 - 29 Dec 2010    Post subject: Reply with quote
Check this out and get that variator changed....
https://www.tunemyscooter.com/50cc-tuning/yamaha-aerox-jog-rr-50cc-malossi-tuning-guide/
Then check out the epic examples of pedbois at the bottom of the page.......83 Mph from a Neos 50..........
connornrg
PostPosted: 23:28 - 29 Dec 2010    Post subject: Reply with quote
Utter bullshit........ with a 125 engine fitted in a neos (how did that get that there officer....... thought it was a bit fast Whistle Thinking Whistle ) it didnt even hit 80 =/
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
Moped Madness
PostPosted: 22:49 - 31 Dec 2010    Post subject: Reply with quote
Livefast123 U Dont Have To Up-Jet If Uve Only Got A Pipe On It :/
Try Putting A K&N Air Filter On InStead Of The Standard Box Airfilter Also Make Sure The Filter Pipe From The Carb To The AirFilter Hasnt Come Off As That Will Cause It To Box Madness.
Make Sure Ya Airfilter Hasnt Got Wet Either.
NRG (50CC) 60MPH+ BROUGHT FOR £135.00 CAT C NOW WORTH £500 EASY SHES A BABY:)
stonesie
PostPosted: 22:54 - 31 Dec 2010    Post subject: Reply with quote
https://farm5.static.flickr.com/4013/4406814328_d92309f386.jpg
Livefast123
PostPosted: 23:11 - 31 Dec 2010    Post subject: Reply with quote
Obviously speaking from years of 2 stroke experience Thumbs Up
If you change the airflow charge into and out of an engine then you have to jet suitably but then you should know that having a 60 + Mph NRG. Confused
The op asked how to improve his bike not blow it up.
grantp
PostPosted: 23:23 - 31 Dec 2010    Post subject: Reply with quote
Found the problem,
HT Lead wasn't on the spark plug correctly, was literally hanging off. So replaced spark plug aswell whilst I was there and pushed the ht lead all the way on, there was some crappy sparkplug in there so changed it for an ngk one and that has sorted my accelaration problems.
I will still be getting the rollers sorted out sometime within the next month.
Thank you everyone for your help, much appreciated.
Livefast123
PostPosted: 23:27 - 31 Dec 2010    Post subject: Reply with quote
When you've done a few miles then take the plug out and see what general colour it is just to check the jetting is correct.
You don't want a white or black plug as this indicates leans and rich mixture respectively.
grantp
PostPosted: 23:28 - 31 Dec 2010    Post subject: Reply with quote
The old one was like a tan/browny colour. Is that ok?
grantp
PostPosted: 23:32 - 31 Dec 2010    Post subject: Reply with quote
Thats good then, cheers for the help mate.
connornrg
PostPosted: 22:17 - 03 Jan 2011    Post subject: Reply with quote
LOL WUT!
Pipe = Rejet. dick
grantp
PostPosted: 12:37 - 12 Jan 2011    Post subject: Reply with quote
Sorry to bump the thread. What rollers would you recommend to change to? The standard rollers are 6.5g. What would be the best to change it to? Bearing in mind I also have a tecnigas exhaust.
Thanks for any help.
cb1rocket
PostPosted: 21:02 - 12 Jan 2011    Post subject: Reply with quote
well how well is it rev-ing? Is the accerlation lacking still?
Whats the top speed at the mo?
Generally you need to go to lighter rollers, the exhuast website (if any) should tell you what rollers are needed.
The last post was made 15 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.84 - MySQL Queries: 14 - Page Size: 118.81 Kb
