| nisp |
 nisp Scooby Slapper
| MickC |
 MickC Spanner Monkey
 Posted: 23:58 - 03 Jun 2011 Post subject: |
Could be crud sticking things up in the carb/s pull em off and check the float chambers for deposits. Putting some 'magic bullet' in the tank would help to clear out any crud in the system. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| nisp |
 nisp Scooby Slapper
 Posted: 17:04 - 04 Jun 2011 Post subject: |
not the carbs, there clean as a whistle!! quadruple checked today.. ____________________ Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976 |
| MickC |
 Posted: 17:29 - 04 Jun 2011 Post subject: |
Are all the hoses connected properly?, if air can leak in anywhere your rpm will increase. Try spraying 'easy start' around the insulators on the carbs (where the carbs go into the head) and see if your rpm increases if so check them for damage and make sure they are clamped tightly. ____________________ XX XXXx
| stinkwheel |
 Posted: 18:48 - 04 Jun 2011 Post subject: |
Another vote for an inlet manifold air leak. Test exactly as MickC says.
A second possability is a faulty auto-advance if it's a points model. Check it for broken/detached springs. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| nisp |
 nisp Scooby Slapper
 Posted: 00:11 - 05 Jun 2011 Post subject: |
found the problem i hope,
manifolds were lose, they were tightened to the max but there still must have been a leek so i put blue insta gasket all over the joint and shoved the whole assembly back together and didn't seem to hang around at all
problem solved must have been such a small amount tho
Job done it was really starting to get on my nerves  ____________________ Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976 |
| MickC |
 Posted: 11:04 - 05 Jun 2011 Post subject: |
We like simple solutions! ____________________ XX XXXx
| nisp |
 nisp Scooby Slapper
 Posted: 22:48 - 05 Jun 2011 Post subject: |
yeah, i guess since the clamps were tight i thought it was something else
now i can have the full use of my brand new pistons  ____________________ Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976 |
The last post was made 15 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
