Gilera DNA is Squeaky. URGERNT help wanted... Please??
WillSwain95
PostPosted: 18:26 - 23 Jan 2011    Post subject: Gilera DNA is Squeaky. URGERNT help wanted... Please?? Reply with quote
Hey, i got a small problem with a Squeaking noise coming from somewhere on the bike when the lights are on and the throttle is opened. With lights off - No Squeak. With lights on - Loud Continuous Squeak.
This squeaky business has occurred before. On my brothers car. When he had his lights on, his alternator belt would slip and cause a squeaking noise, i thought this could be the problem on this, but it has a magneto instead of an alternator. It sounds just like a belt is slipping but i only know of 1 belt on this bike atm...
Anyone got any suggestions on how to fix it or had the same experience? if so. How did you fix it.
Thanks.
Will.
Paxovasa
PostPosted: 08:38 - 24 Jan 2011    Post subject: Reply with quote
Give the mouse some cheese Thumbs Up
lukamon
PostPosted: 13:25 - 24 Jan 2011    Post subject: Reply with quote
maybe your lights are shorting to your horn. they are on the same cluster after all.
take the side panel off and pull of the one spade connector on the horn, which is located just above the radiator Thumbs Up if it stops theres your problem.
killa wrote: Im an ass man myself
WillSwain95
PostPosted: 19:07 - 24 Jan 2011    Post subject: Reply with quote
Sad i can't get a side fairing off... the bottom screw is completely rusted out! any idea how to get a rust screw out? Razz
WillSwain95
PostPosted: 19:38 - 24 Jan 2011    Post subject: Reply with quote
Sad think i'm gonna have to snap the plastic around the screw to get it off. those screws are literally screwed!! Sad
c_dug
PostPosted: 19:40 - 24 Jan 2011    Post subject: Reply with quote
If the fitting of the screw is still good then just make sure you use the correct driver and it should come out still.
If it has been rounded then it depends how bad the damage is and what it goes into but there are all sorts of methods, first of all though assuming you are pressing against something solid then I would advise making sure you are using the correct screwdriver and then apply lots of downwards pressure while turning it anti-clockwise.
WillSwain95
PostPosted: 20:22 - 24 Jan 2011    Post subject: Reply with quote
https://i715.photobucket.com/albums/ww159/S95-Kita/My%20Bike%20xD/DSC00732.jpg
WillSwain95
PostPosted: 20:23 - 24 Jan 2011    Post subject: Reply with quote
And they're like that on both Sad
WillSwain95
PostPosted: 20:54 - 24 Jan 2011    Post subject: Reply with quote
thinking of taking it down to the bike garage down the road and getting them to check it out. im sure they'll know. i'm a rookie to bikes. well been riding motorcross for years, but nothing compared to road engines.
c_dug
PostPosted: 23:31 - 24 Jan 2011    Post subject: Reply with quote
As long as it is metal is is going in to and not another panel I would try what I said above, I have got worse screws out by using a good screwdriver and some pressure, either that or perhaps consider buying an impact driver.
Glenben92
PostPosted: 23:43 - 24 Jan 2011    Post subject: Reply with quote
What's wrong with listening to where it's coming from? i'm confused
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
WillSwain95
PostPosted: 17:16 - 25 Jan 2011    Post subject: Reply with quote
It doesn't make a sound until i'm doing about 10mph+ so it's really hard to tell where it's coming from...
Glenben92
PostPosted: 18:00 - 25 Jan 2011    Post subject: Reply with quote
So either: put it on the centre stand / devise a centre stand if it doesn't have one
or: it's gotta be something wheel related.
You need to replicate the sound with the bike on it's stand basically. That's the next logical step in my eyes
WillSwain95
PostPosted: 18:10 - 25 Jan 2011    Post subject: Reply with quote
Yeah ok, thats a good suggestion.
Thanks.. Might test tonight and tell you the outcome
WillSwain95
PostPosted: 18:45 - 25 Jan 2011    Post subject: Reply with quote
Any Chance it just could be a low battery? because the battery is quite low and i dont imagine that about half a mile can charge it it. It doesn't have enough power to Electric Start it atm.
My dad thinks it could be a low battery
If not, possibly an "out of date" drive belt. The strength and leverage to get the casing off was immense, dont think it's ever been undone, the bike only done 1816 miles but it's an x reg (year 2000)
Glenben92
PostPosted: 23:06 - 25 Jan 2011    Post subject: Reply with quote
Sorta presumed you'd tried the obvious! Belt, Belt, Belt, Belt
WillSwain95
PostPosted: 23:07 - 25 Jan 2011    Post subject: Reply with quote
Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile
IT'S FIXED!!! Very Happy Just the battery needed charging Neutral Laughing
A Nice Night Cruise on a dna50 was funnn Smile
Glenben92
PostPosted: 23:40 - 25 Jan 2011    Post subject: Reply with quote
I don't get how a low battery could POSSIBLY cause a squeak. Anyone care to explain?
WillSwain95
PostPosted: 16:01 - 26 Jan 2011    Post subject: Reply with quote
Best guess is that there wasn't enough electricity to power them? something to do with the belt didn't have enough power to move right or something...?
PostPosted: 16:05 - 26 Jan 2011    Post subject: Reply with quote
The electric hamsters were hungry?
Triumph Trophy Launch Edition
WillSwain95
PostPosted: 16:24 - 26 Jan 2011    Post subject: Reply with quote
i said to my dad i think i'll have to get a new belt, so yeah. Cheers for the help Rob, Smile
I'll get a belt in the next couple of days and fit it then Smile
The last post was made 14 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 131.09 Kb
