| ORourke |
 ORourke Two Stroke Sniffer
 Posted: 14:49 - 28 Nov 2010 Post subject: Suzuki GSX400E budget build |
Hello,
I'm new to this forum, but by no means new to biking. I live in the Czech Republic at the moment, which has it's issues when trying to source anything for older bikes. I've had bikes for the past 9 years, and couldn't imagine life without one. Mortgage and imminent family plans have limited my current line up to this:
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4712.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4706.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4707.jpg
It's a 1985 Suzuki GSX400E imported from German. I bought it a year ago and since have invested only in new camshafts (to up the power from the restricted state it was in), new handle bars and mini indicators.
The winter plan is to sort out the worst of the cosmetic faults, and bring the bike a bit up to date and remove as much weight as possible - and all this on a very strict budget.
The first thing i'll be doing is fixing the seat cowling. The previous owner attached a top box right onto the fragile plastic seat cowling, rather than using a proper mounting frame - the result being a badly cracked fairing:
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4705.jpg
I've stripped off the graphics ( new plans for the paint job anyway) and prepared everything for a bit of plastic filler and then some sanding in prep for the new paint.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4728.jpg
While the fairing is off i'll be taking a look at what I can do with the rather large and ugly rear mudguard.
While i'm doing that, i'd like to ask for some opinions as well. The wheels have black inners with alloy rims, they look awful at this point, and i'm in two minds whether to polish up the alloy or whether to paint the entire wheels either white or metallic blue. Let me know what you think.
Hope people will enjoy the rebuild.
Tyrone O'Rourke[/img] |
| sniff6 |
 sniff6 World Chat Champion
| blurredman |
 blurredman World Chat Champion
 Posted: 23:19 - 29 Nov 2010 Post subject: |
Indeed, welcome though. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| Teflon-Mike |
 Teflon-Mike tl;dr
| ORourke |
| ORourke |
 Posted: 16:09 - 03 Dec 2010 Post subject: |
Just been doing a bit of experimenting today, don't want to do much until I get the answer about the tyres, might take a few weeks to get.
Earlier this week i removed the rear mudguard in an attempt to clean up the lines of the bike. It looked IMO a lot better without it, but making up a blanking plate under the seat to stop muck flying from the wheel onto the underside of the seat looked like a bit of a challenge.
I attacked the scrap guard this morning, I like the way it looks, though it will need a bit of trimming here and there so it doesn't poke out from underneath the fairing.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4730.jpg
As a result I'd lost the number plate mounting. Digging around I found an old set of rear 'cat-eye' lights that i'd once bought on the cheap for some other bike. They'd never been used and ended up damaged after a move. The alloy plate they were mounted to was perfect, however, so I cut that to size so that it would bolt up to the rear end with the stock rear light
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4732.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4731.jpg
All told i'm quite happy with the new look:
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/100_4733.jpg
I also had a crack at the plastic filling, and think I may have added too little hardener to the mix, as it's still not dried 3 hrs after applying it - 45mins is what the can says. I'll leave it till tomorrow and see if it sets.
| ORourke |
| blurredman |
 Posted: 12:36 - 07 Dec 2010 Post subject: |
I like the progress and the rear look!!  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| hmmmnz |
 hmmmnz Super Spammer
| Darth |
 Darth World Chat Champion
 Posted: 13:56 - 08 Dec 2010 Post subject: |
Top work so far Always like a reading these low budget show and tells  ____________________ Harold_Shand wrote: I suppose it's like anything, you get your fingers burned when you start out, you learn from it and eventually become a complete arsehole about the whole thing. |
| ORourke |
 Posted: 15:45 - 08 Dec 2010 Post subject: |
More pics to come - i'm actually planning to see this one through
Meanwhile had a great email from Suzuki that they are going to send me the letter I need to get the wider (90/90-18F and 110/90-18R) tyres approved at the MOT. Wonderful, all that extra wideness. And best of all, it means I can go full steam ahead with the project.
Meanwhile, has anyone here had any good/bad experiences with the following brands/models of tyres:
Bridgestone BT45
Metzler ME77
Pirelli City Demon
And now that I have a green light, the basis for the rest of the projects is:
-New tyres (I know it's getting boring, I won't mention them much anymore)
-New sprocket kit, the bike is now on the original set up, but it revs to high while cruising for my liking, so i'll be dropping a few teeth to the set up that was on the bike when I bought it- drops revs at 80km/h from 3500 to a much more pleasing 2900. The engine can pull it no problem, and with the ratios so close, acceleration isn't really harmed.
-New headlight- thinking of a clear lens, and playing around with the position, maybe lower it a bit.
-Make/find some rear sets, or get the pegs a bit further back somehow, and replace those comfy looking rubber pegs with something a bit more stylish
-lots of polishing
-recover the seat
- do something with the handlebars, they are a bit wide in pracitice, so might take a few cm off them.
-find some mirrors that will actually show more than my shoulders - maybe some bar end mirrors.
-Do something with the clocks - i really want a Koso digital, but at 220gbp, it's not exactly a budget buy... we'll see...
- Loose as much weight as I can ( I've already saved about a kilo with the rear mudguard, so I'm hoping that something more will give
Apart from that I'll see where it takes me, might have more ideas on the way. |
| Darth |
 Posted: 16:10 - 08 Dec 2010 Post subject: |
BT45  ____________________ Harold_Shand wrote: I suppose it's like anything, you get your fingers burned when you start out, you learn from it and eventually become a complete arsehole about the whole thing. |
| Moo. |
 Moo. World Chat Champion
 Posted: 17:23 - 08 Dec 2010 Post subject: |
+1 BT45  ____________________ A2 Passed 18/6/10 |
| ncrn |
 ncrn World Chat Champion
 Posted: 18:11 - 08 Dec 2010 Post subject: |
| ORourke |
 Posted: 15:52 - 12 Dec 2010 Post subject: |
Looks like BT45 are the popular vote. I'll keep that in mind when I go shopping.
Meanwhile I managed to get to the garage this morning, and got a few things done.
Rear wheel cleaned - it still needs a going over with polish, but the black inserts are so dirty from chain grease etc that I'll wait till the wheel is out and then give it a proper clean.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4796int.jpg
The bottom cover of the clocks will need some treatment, this chrome strip isn't everything it should be and will be repainted in metalic blue.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4797int.jpg
I also had the front wheel out again. The mudguard had never been mounted very straight, and I decided to see what was wrong.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4798int.jpg
Turns out the metal mounting bracket/fork brace was a bit out of shape. A bit of heating it up and tactical bending was all that it took to get this back in shape, and the result was a mudguard in line with the wheel. This probably had a negative effect on the handling, so i'm glad it's done.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4799int.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4800int.jpg
Oh, and last night I ripped off the old seat cover. I cannot find any staples, so I'll have to go to the hardware store before putting a new cover on.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4794int.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4795int.jpg
I've more or less just taken a piece of leather and cut it to shape. If this turns out ok, i'll keep it, otherwise i'll be looking for other cover options.
The time has come to start shopping for those parts that I wanted, but my guess is that they won't start arriving until January, in the mean time I'll be doing a bit of cleaning and polishing. |
| ORourke |
| ORourke |
 Posted: 16:57 - 19 Dec 2010 Post subject: |
Decided to get the dirty work over with, and did the valve clearances today. It's not hard as such, just a pain what with having to remove so much to get the valve cover off. All the valves were, happily though rather annoyingly given the time spent getting to them in spec. I was also happy to see the new cams I put in earlier in the year were looking good- you never know seeing as I fit them myself.
https://i38.photobucket.com/albums/e130/tyroneorourke/102_4817int.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/102_4819int.jpg
https://i38.photobucket.com/albums/e130/tyroneorourke/102_4818int.jpg
The only things to go wrong were the above hoses, which had gone a bit hard over the years and wouldn't come free from the tap. New hoses will be used. Also the tacho drive retaining bolt sheared while I was tightening it in the head. Fortunately I felt the shear happening and was able to withdraw the bolt fully - when I got it out it was in two piece but for a mm thick strip holding them together. Talk about luck. |
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 00:36 - 22 Dec 2010 Post subject: |
Really liking these old suzukis in the show and tell section. keep up the good work
So, whats next? More engine stuff, or is it just a bit of a clean up? ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| ORourke |
 Posted: 10:37 - 22 Dec 2010 Post subject: |
| rob_scott92 wrote: | Really liking these old suzukis in the show and tell section.  keep up the good work
So, whats next? More engine stuff, or is it just a bit of a clean up? |
Next is a big shopping day- 'man shopping' i like to think of it as, the only kind of shopping I can stand. I've got a new headlight to get (not sure if it's clear in the pics, but the glass has a nasty crack in it left by some low life ****** who I think tried to steal the bike(in the bad old days when I didn't have a garage), but finding it locked to my cars towbar with a rather huge lock and chain, ran off with the cover and seems to have had a go at punching the light I'll also be getting the chain set, and the tyres (i've decided for Avon Roadriders)
The engine won't be getting any more work done to it, it's quite alright despite the 41000km, no smoking, no oil consumption, no nasty noises. The only thing I have to do is remove the sump and clean the gauze on the oil pump intake. I would have liked to K&N it, but I haven't found anyone here who would want to jet the thing on a dyno after that. I guess I'll have to ride the thing to the UK and have it done there if I want it
I've thought long and hard about what I want to do with this bike. In early autumn I wanted to make it into a cafe racer, but after some stripping of the bike, it became clear that would involve a complete rebuild with different body parts, and that wasn't what I was after. Considering i'm a bit impulsive, the fact I didn't cut the whole thing up and then loose interest is something of a miracle - I must be getting wiser by the year.
The next thing I wanted to do was street-fighter it, but again, the tank and panel style just doesn't work well as a street fighter, in fact until I saw a picture of what this bike looks like with them, I wanted to go with a twin headlight setup.
So the final plan at this point is to work on the existing lines of the bike, and mirror the Katana as much as possible, and make it look sleek.
After all that rambling, I guess the answer to your question is that its really only a bit of a clean up from here on |
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 17:41 - 22 Dec 2010 Post subject: |
are you english then?
Czech Republic seems an interesting place to end up.. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| ORourke |
 Posted: 17:52 - 22 Dec 2010 Post subject: |
| ORourke |
 Posted: 18:50 - 28 Dec 2010 Post subject: |
Hope everyones had a good Christmas. I got to the garage today and came across a problem I hadn't though of when modifying the rear mudguard. The rear indicator mounts were rather large, and a good part of them was visible below the mini indicators i'd fitted. While this hadn't been an issue with the original mudguard, it looked ridiculous with the new design.
The original brackets
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4855int.jpg
Below the yellow wire is the piece that hangs in the air below the fairing - so I decided to get rid of it
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4856int.jpg
And this is what it looks like now, took off the bottom part of the bracket and drilled a hole for the indicator.
https://i38.photobucket.com/albums/e130/tyroneorourke/Suzuki%20rebuild/102_4857int.jpg
A bit of paint will follow.
I am thinking of getting an LED rear light with integrated indicators to clean up the lines, but so far I've not been impressed with the brightness in daylight of these lights.
I've placed a few orders for new parts, but it seems the entire bike part world is on holiday and then taking inventory till the 10th of Jan, so I'm going to have to wait a while for the new chain and sprockets, headlight, hoses and sundry bits. |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 00:17 - 29 Dec 2010 Post subject: |
| ORourke wrote: |
I had one of those for my Bandit, and I must admit, I wasn't stunningly impressed, in hindsight. It might be OK if the fitting has a tinted lens, as the SV's tail light is pretty visible, but the ones with the white lens are crap. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| ORourke |
| Digitalize |
 Digitalize Nearly there...
 Posted: 17:57 - 03 Jan 2011 Post subject: |
Bikes looking really good.
Are you keeping the classic paint scheme or going for something different? I really like the white and blue  ____________________ 1998 CB600F Hornet |
The last post was made 15 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
