Can easystart be used to spray in carb ?
rmurphy16
PostPosted: 15:24 - 11 Feb 2011    Post subject: Can easystart be used to spray in carb ? Reply with quote
My carbs dirty, only thing i have is easy start, can this be used?
r.murphy
PostPosted: 15:26 - 11 Feb 2011    Post subject: Reply with quote
Do you want to use it to clean the carb or just start the engine?
Can be used to start the engine (some say not to be used in 2 squeaks though). However I think it would probably be fairly useless as a carb cleaner. Evaporates very quickly.
rmurphy16
PostPosted: 15:28 - 11 Feb 2011    Post subject: Reply with quote
Hi,
i was hoping it could be used as a carb cleaner i'm about to take my carb off in a sec, was going to clean main jet and float bowl,
should i spray the easystart on them, and anywhere else?
thanks
Ryan
r.murphy
Raffles
PostPosted: 15:38 - 11 Feb 2011    Post subject: Reply with quote
Confused
PostPosted: 15:43 - 11 Feb 2011    Post subject: Reply with quote
I wouldn't expect it to work well for cleaning things. A can of brake cleaner would probably be more effective (although I would take care with using it on plastic and rubber components).
If there is just dirt in there then anything will flush it away (including WD40). However if you have dried fuel inside the jets I would doubt that the easy start would stay liquid long enough to have any significant effect dissolving on it.
Teflon-Mike
tl;dr
PostPosted: 15:49 - 11 Feb 2011    Post subject: Reply with quote
If your carbs need 'cleaning' as in jets unblocking, then squirting stuff in the choke really isn't going to do much.
Dont know what carb it is, but its no mamoth and complicated task to take the carb off, and wip the float-bowl off, remove petrol residues with deturgent and an old tooth-brush, blow throuh the jets and re-assemble, if needs with a new float-bowl gasket cut from a cornflake packet (DO NOT use squeezee gasket unless you like petrol leaks and more clogged jets and valves!)
rmurphy16
PostPosted: 15:51 - 11 Feb 2011    Post subject: Reply with quote
I have some WD40 sitting here would that work better for cleaning out the carb than the easystart then?
r.murphy
PostPosted: 15:57 - 11 Feb 2011    Post subject: Reply with quote
To generally flush things out it should be fine. However with carbs often the problem is old fuel that has dried and left a hard varnish like residue. Dissolving and removing this is difficult and I suspect WD40 wouldn't be that effective
rmurphy16
PostPosted: 16:01 - 11 Feb 2011    Post subject: Reply with quote
I'll try tooth brush, and see how i get on, hopefully works
Thanks for the help.
r.murphy
The last post was made 15 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 63.85 Kb
