Help with indicator mystery
emmababyb
PostPosted: 05:10 - 27 Jan 2011    Post subject: Help with indicator mystery Reply with quote
I have a mot coming up and i seem to have a problem with getting my indicators working. The regulator rectifier I replaced as I thought that was the problem but they worked for about a day and then gave up the ghost. I have been using arm signals cos i cant figure out what the problem is but the mot is looming and I dont know what to do. The switch is ok and the rest of the electrics work fine. There is only one fuse and that did blow but i replaced it, that was due to a dodgy earth on my battery which just needed a screw tightening, any suggestions please? I am a single mum of 3 and its me only transport and i need to be able to get to the shops and back. Can i remove the indicators and pass a mot??
Teflon-Mike
tl;dr
PostPosted: 05:46 - 27 Jan 2011    Post subject: Re: Help with indicator mystery Reply with quote
OK.... lets chill out a bit, slow down and work this through!
First off, if the bike was built AFTER 1985 then, no, you cant remove the indicators for MOT... wouldn't sort the problem anyway.... because 'the problem' is you waving your arms about doing chicken impressions rather then flipping a switch!
Now, HOW do they not work? Lets start at the beginning.
1/ Whats the bike? Make, model, year.
2/ you put the key in. You start engine. What happens? anything 'strange'?
3/ engine running, turn left indicator on... what happens?
Does anything light up?
Front left indicator, back left indicator, tell-tale light on the speedo?
Do you get a flash then nothing? Do you get nothing. do you get constant light, without it flashing?
HOW, 'don't' the indicators work?
Next, not sure why you'd replace the regulator for an indicator fault... is this relevent? Did you change it JUST because the indicators weren't working, or because you had a general electrical fault, like nothing worked!
When did the indicators stop working? You mention the battery earth and fuse. THAT little lot suggests general electrical fault, and regulator being replaced becouse nothing worked, and since fixing that, the indicator problem remaining.
Making a HECK of a lot of presumptions in there, makes me suspect that in de-bugging other faults you may have dislodged wire on indicator flasher, or shorted out the flasher unit, as that normally sits in close proximity to the battery, BUT, would be jumping to an awful lot of conclusions!
Electrics tend to be annoying, but end of the day they are a logical system, and taking time, and working through logically, identifying and isolating variables in turn, you get to the solution.
SO.... lets take a breath and work it through.
Fill in the blanks on the circumstances.
Explain the symptoms.
Then we can work it through.
Where are you? Do you have a wiring diagram? Do you have a Multi-Meter?
emmababyb
PostPosted: 03:55 - 15 Feb 2011    Post subject: Re: Help with indicator mystery Reply with quote
Its a NRG piaggio dd. 2006 plate.
It starts up and the panel lights up with the milage and petrol info etc. Not anything strange, hooter works and starter but not the indicators, the high beam works ok too.
Nothing at all.
Nothing at all, I had it looked at a while ago and shelled out £40 for someone to look at it and tell me that the switch worked ok and there was power going thru the wires and couldnt see why it wouldnt work, the only thing he put it down to was the regulator rectifier he said replace that and it shud be fine. Went and bought one, fitted it, turned off the key on the lights worked but lasted about a few days and then stopped working after blowing a fuse. The starter and horn stopped and i had to start manually with kick start, it Kept blowing fuses and figured it to be a loose connection on the battery terminal. New fuse and the horn and starter worked and lights but no indicators again. Confused!!
The regulator/regtifier are one unit on this model and year so you have to replace as one unit.
Where are you? Do you have a wiring diagram? Do you have a Multi-Meter?[/quote]
I havent got a multimeter, not sure what one of them is. I can get a wiring diagram off a site online. I am leicester.
truslack
PostPosted: 09:30 - 15 Feb 2011    Post subject: Re: Help with indicator mystery Reply with quote
Do Piaggios have the flasher relay built into the regulator, in a similar way to Derbi?
Odie
PostPosted: 10:16 - 15 Feb 2011    Post subject: Reply with quote
where are you?
I am in Derby but have to visit friends in leicester on saturday, i fix bikes by the way Mr. Green
fiery tupp
PostPosted: 16:14 - 15 Feb 2011    Post subject: Re: Help with indicator mystery Reply with quote
If they worked for as you say about a day ( it temporarily solved the problem ) I would guess that could be it & you could possibly have bought a duff one ? ( chinese by any chance ? )
If you can't fix it with a hammer , use your head .
PostPosted: 16:38 - 15 Feb 2011    Post subject: Reply with quote
Is it a 50cc? If so you don't need indicators. Cover them up and put tape over the switch.
If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise).
fiery tupp
PostPosted: 17:48 - 15 Feb 2011    Post subject: Reply with quote
I think, if fitted they need to work .
https://www.ukmot.com/bike_1-5.asp#Text_top
drzsta
PostPosted: 19:42 - 15 Feb 2011    Post subject: Reply with quote
relay is fucked.
PostPosted: 19:51 - 15 Feb 2011    Post subject: Reply with quote
drzsta wrote:
relay is fucked.
Wouldn't they come on but not flash in that case?
cb1rocket
PostPosted: 21:48 - 15 Feb 2011    Post subject: Reply with quote
chris-red wrote:
drzsta wrote:
relay is fucked.
depends on the relay itself, some have 2 terminal and some have 3. The two type terminal are in my experiance the ones that just stay on.
Any how its a Piaggio and if thinking right, yes the relay is built in the reg/rec. Could rewire to go into a single independant relay.
emmababyb
PostPosted: 02:52 - 04 Mar 2011    Post subject: tested Reply with quote
I looked at the bulbs and they seem ok, next step anyone please??
cb1rocket
PostPosted: 12:13 - 04 Mar 2011    Post subject: Reply with quote
need to check the wiring possible corrsion damage, but i'm guessing its still the relay. You won't know for sure until you find a replacement.
need to find a block like this which I assume will be under the front panel somewhere
https://cgi.ebay.co.uk/PIAGGIO-NRG-POWER-50-2005-Multi-Function-Relay-/250728530975?pt=UK_Motorcycle_Parts&hash=item3a6095c41f
jasonDT
PostPosted: 20:30 - 04 Mar 2011    Post subject: Reply with quote
COVER ALL LIGHTS UP WITH TAPE HEADLIGHT BACK LIGHT INDERCATORS AS LONG AS THE HORN WORKS AND YOU DONT USE BIKE AT NIGHT FOR THE TIME BEING UNTIL YOU SORT THE PROBLEM BOOK IT IN FOR A DAY TIME MOT THATS WHAT IVE DONE WITH MINE UNTIL I GET MY INDERCATORS SORTED OUT I HAVE A YAMAHA DT 125 LC 1986 HOPE THIS HELPS YOU FOR THE TIME BEING UNTIL YOU HAVE SORTED THE PROBLEM
JAY
hi to all and thanks for your help
The last post was made 14 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.38 - MySQL Queries: 14 - Page Size: 88.47 Kb
