Show & Tell - Swapping PC case
McJamweasel
BCF Junkie
PostPosted: 15:55 - 24 Mar 2011    Post subject: Show & Tell - Swapping PC case Reply with quote
After upgrading my machine in september I decided that it was time to replace my 6 year old Antec Sonata case too. I settled on the Fractal Design Define R3, a gorgeously understated case with good cooling and lots of soundproofing to keep the noise in.
https://www.kustompcs.co.uk/acatalog/1579.jpg
So, first off here is the existing system.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/01Medium.jpg https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/02Medium.jpg
First job was to strip out the cabling, disk drives and the expansion cards:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/03Medium.jpg
Next out came the motherboard and PSU, leaving a rather sad looking, empty case:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/04Medium.jpg
And a pile of components (AMD Athlon X2 250, 4Gb DDR3, MSI 770-C45 motherboard, Gigabyte GTX460 1GB and drives.):
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/05Medium.jpg
Now time for the build up. I started by fitting the fans. There are 4 120mm fans in there, 1 bottom & 1 front on intake and 1 top & 1 rear on exhaust duty. The front is motherboard controlled and the other 3 are run by a fan controller on the case. There's still space for another 120mm in the front and a 120 or 140mm in the roof and in the side panel. The front, floor & PDU intakes are covered with filters, the unused side panel & roof mounts are covered in more sound proofing.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/cooling.jpg
Time for the disk drives next. The hard drives are in these removable trays with rubber supports to damp the vibrations.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/07Medium.jpg https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/08Medium.jpg
Next up was the PSU. The Define has plenty of space behind the motherboard tray for the cabling. The only niggle that I have is that the rubber gromets on the cable holes is a bit soft, so they easily pull out of place when running cables through.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/09Medium.jpg
Now it was time for the motherboard.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/11Medium.jpg
Next up were the Wi-Fi and GPU cards and the cabling.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/12Medium.jpg
Alas, this is the extent of the cable tidying job that I had to do:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/13Medium.jpg
Tidying done. Not the best job, but good enough. I've used rapstrap in places rather than cable ties, they work very well.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/14Medium.jpg
And the finished build:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/15Medium.jpg
Temperatures are basically unchanged from the Sonata, under load (Furmark for GPU and Prime95 for CPU) I get 72 C for the GPU and 40 for the CPU with all case fans on minumum (room temp 21 C). If I up them to full it only makes a couple of degrees difference so I won't bother, I prefer the quiet.
The Sonata was 2~3 degrees higher with only 2 case fans, so I think that speaks volumes for the cooling efficiency of that (admittedly noisier) case.
Frost
PostPosted: 16:29 - 24 Mar 2011    Post subject: Reply with quote
I did something very similar. I got a big CPU fan, the quietest i could find and upgraded to a soundproofed case with big fans. On starting the system up it ran exactly as cool as my old one, but wasn't much quieter. I messed around in BIOS and with some software and turned the CPU fan down from about 5000rpm to about 800. The secondary case fan didn't even need to be plugged in!
After this the system was basically silent. It's within arms reach but i can't hear a thing.
Neorion
PostPosted: 16:46 - 24 Mar 2011    Post subject: Reply with quote
Nice improvement, pop an SSD or a hybrid drive in there and you would be laughing.
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
Frost
PostPosted: 18:07 - 24 Mar 2011    Post subject: Reply with quote
If you fancy a project, you could always go for a water cooling system
The last post was made 15 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.16 - MySQL Queries: 14 - Page Size: 44.75 Kb
