NSR running issue
Livefast123
PostPosted: 12:47 - 06 Jun 2011    Post subject: NSR running issue Reply with quote
Just done a top end rebuild on my NSR and it was running great, completed running in period and got good compression etc. It also had a new thermostat and tank (SH) as the old one had rotted through
Yesterday I decided to use it for work so started it up and when I tried to ride away it would just bog so chucked it back in the garage and took the Comet.
Took it for a ride out today and it behaved for around 2 miles then I was doing around 50 when it started chugging like it was running out of petrol. I put more throttle on and it just died. It wouldn't restart without the choke on and if I took it off it would die. I stayed there for around 2 minuted blipping the throttle, put the choke off and it was fine. Travelled another 2 miles down the road and the same happened Evil or Very Mad
Choke on again and start up. I then left the choke on and the bike drove fine and didn't cut out Neutral
Carb was cleaned when i rebuilt it, plug is a fairly new iridium, jetting is standard derestricted jets and ok, air filter clean, 2 x newish inline filters fitted.
I did consider a fuel tank vacuum but it running on choke should surely discount this?
Current ride - Yamaha MT-07
PostPosted: 12:53 - 06 Jun 2011    Post subject: Reply with quote
When this happens open up the petrol cap and see if you here a noise like air rushing in, you could have a blocked breather.
Livefast123
PostPosted: 12:58 - 06 Jun 2011    Post subject: Reply with quote
Thats what i thought Chris but would the fact that it'll run till the cows come home on choke discount that?
I wouldn't normally have 2 filters but I cut the new fuel line too short Embarassed
truslack
PostPosted: 13:23 - 06 Jun 2011    Post subject: Reply with quote
I've never had any luck with inline fuel filters, always seems to cause that issue so it's probably worth replacing with a decent size fuel line.
Livefast123
PostPosted: 13:44 - 06 Jun 2011    Post subject: Reply with quote
Thanks, I'll remove them and try to reroute the fuel line and see if that makes any difference.
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.22 - MySQL Queries: 14 - Page Size: 48.64 Kb
