MBK ovetto 50cc problem
chris vvc
PostPosted: 20:16 - 03 Jun 2011    Post subject: MBK ovetto 50cc problem Reply with quote
hi all i have just been given a non runner ovetto by a mate of mine. i have stripped it all back to the basics, i have seen it has got a good spark, but im not sure if fuel is getting to it, i have been trying to kick start as the electric start does not work, and it seems that it does not want to start at all!!
any help and replys would be very much appreciated
p.s.. i have been reading on the web and i have come across something called a cdi, would that control the fuel?
thanks
chris
chris vvc
PostPosted: 21:12 - 04 Jun 2011    Post subject: Reply with quote
think i have traced the problem back to the fuel tap, so got a new one ordered for Wednsebury.
there seems to be another problem with the electric start. when i press the start button in nothing happens, what are the chances of it being the starter motor?
chris vvc
PostPosted: 15:46 - 08 Jun 2011    Post subject: Reply with quote
right ive sorted the electric start problem.
still got this fooking problem with it not starting, ive put a new fuel tap on it so there is fuel now getting to the carb, put a new spark pug and ht cap on and still nothing. after about 10 minutes of trying to start it i thought ill take the plug out and clean it as it would be covered in fuel, so i take it out and its still bone dry....WTF.
could somebody please help me
p.s it seems to have very good compression
connornrg
PostPosted: 18:40 - 08 Jun 2011    Post subject: Reply with quote
Have you tried fresh fuel?
Is petrol entering the carb? (open the float bowl, if petrol pisses out then yes petrol is entering carb.
Are the jets blocked?(whilst float bowl open unscrew the jet, commonly brass in colour and in the middle of the bowl)
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
Lipsmoker
PostPosted: 20:10 - 08 Jun 2011    Post subject: Reply with quote
I've used to have a Neos 50, the same as the ovetto
Take off the carb blow the jets out
while the carbs off under the inlet manifold is a reed block two Allen screws take that off you will see little petals hold the block up to sunlight and make sure you cant see ANY sunlight coming through.
A Compression tester could be useful too sticking your thumb in the plug whole is never accurate.
On the right hand side of the scooter you will see a little vent cover take off this cover and you will see your stator the stator will have a little metal strip (this times the spark) make sure the metal strip isn't rusty use some light sandpaper and get any rust off.
Fresh fuel wouldnt hurt either.
As for the Electric start problem i bet you wasnt pulling in the brake was you Wink
Four wheels move the body. Two wheels move the soul.
chris vvc
PostPosted: 21:18 - 08 Jun 2011    Post subject: Reply with quote
yes tried all these's, thanks for your reply mate.
chris vvc
PostPosted: 21:32 - 08 Jun 2011    Post subject: Reply with quote
ill have a look at the reed block an stator first thing tomorrow morning also will try and lay my hands on a compression tester aswell.
i have put fresh oil and fuel in today
as for the electric start it was the starter motor, the pulling of the brake still caught me out tho Embarassed
thanks for your reply mate Thumbs Up
Lipsmoker
PostPosted: 00:41 - 09 Jun 2011    Post subject: Reply with quote
No worries let me know how you get on
chris vvc
PostPosted: 10:16 - 09 Jun 2011    Post subject: Reply with quote
had the reed block off an that looks ok
gone to check the stator, to get to it is there a metal dish protecting it with a 17mm nut? if it is i need some sort of locking tool to hold the dish in place while i crack the nut?
booked a week off work to get this piece of shite on the road, its now thursday and i haven't even got it started lol
thomp1983
PostPosted: 14:44 - 11 Jun 2011    Post subject: Reply with quote
take the carb off, get some carb cleaner and spray a small amount into the intake stub the carb fit's into, refit the carb then see if it will start, if it starts on carb cleaner then fuels not getting through the carb
chris
chris vvc
PostPosted: 18:03 - 13 Jun 2011    Post subject: Reply with quote
chris
ill give it a go tomorrow and let you no
thanks for the reply mate Thumbs Up
chris
chris vvc
PostPosted: 21:45 - 17 Jun 2011    Post subject: Reply with quote
right then i got the bike back from my local bike shop as i gave up on it.
he said at some point the engine has seized then sort of freed it self and in doing so has left scratches in the barrel, does that make sense?
is the engine completely shagged or can i buy one of these kits and fix it in the link below?
https://cgi.ebay.co.uk/NEW-BARREL-CYLINDER-KIT-MBK-OVETTO-50-50CC-AC-98-03year-/220759056014?pt=UK_Motorcycle_Parts&hash=item336643de8e#ht_5176wt_1139
thanks
chris
Nope.
PostPosted: 06:21 - 18 Jun 2011    Post subject: Reply with quote
thanks
chris
If its heat seized then its likely that the rings are buggered.
I wouldn't buy that kit unless I wanted it too seize again though. Its cheap chinese tat. My mates just been through 3 of them in about 5 months...
chris vvc
PostPosted: 15:37 - 18 Jun 2011    Post subject: Reply with quote
thanks
chris
would this kit sort it then?
https://cgi.ebay.co.uk/barrel-piston-kit-Yamaha-YN50-Neos-98-04-/190378334723?pt=UK_Motorcycle_Parts&hash=item2c536eda03#ht_2537wt_952
or do you think im better off getting a running engine off ebay?
thanks
chris
timsmith
PostPosted: 17:24 - 18 Jun 2011    Post subject: Reply with quote
I wouldn't bother to buy a second hand engine from E-bay as there is no guarantee that it is any better than the one you have. Have you taken the head off and had a look at the state of the bore? if it is scored then treat it as scrap. Don't buy a cheap barrel from any old where but one of the uk based specialists from E-bay should be ok. Don't forget to get a gasket set and if you are feeling flush a new little end while you are in there. good luck
Tim
chris vvc
PostPosted: 16:18 - 19 Jun 2011    Post subject: Reply with quote
Tim
treat the engine as scarp or just the barrel? also where do the the small end bearings go?
sorry about the questions
thanks
chris
chris vvc
PostPosted: 18:24 - 22 Jun 2011    Post subject: Reply with quote
right then, iv took the head and barrel off to check whats going on, it does not look good, the piston and the barrel are pretty badly marked (piston ring is still on)
what are the chances of it doing damage to the whole of the engine, and not just the top half ?
thanks
chris
Nope.
PostPosted: 18:47 - 22 Jun 2011    Post subject: Reply with quote
thanks
chris
Not a lot. You'd know if the crank had snapped.
The bearings could be shot of course.
Is the circlip still on the gudgeon pin?
chris vvc
PostPosted: 19:20 - 22 Jun 2011    Post subject: Reply with quote
thanks
chris
no the crank as not snapped
the bearings look intact
yeah the circlip is still on the gudgeon pin,
i carnt see anything in there what shouldn't be there either. do you think one of them barrel and piston kits should do it then?
chris
Nope.
PostPosted: 20:45 - 22 Jun 2011    Post subject: Reply with quote
chris
Well, put it this way, you could get one of those kits and it MIGHT be fine. One of my friends has been through 3 cheap chinese kits in the space of 3 months because they keep seizing or breaking circlips.
Having just looked around it doesn't seem as though there are many alternatives so if you do get one of those kits I suggest that you are very careful when installing it and once its running go VERY easy running it in. Dismantle it at 20 miles and check the circlip, then again at 60, then again at 100, then again at 150, then again at 200 all the way too 500 miles when it should be run in. You shouldn't really have too do this but as I say, my friends moped is eating cylinders.
Oh, and take a picture of your bore now and bung it up here. It might not be that bad.
chris vvc
PostPosted: 17:53 - 23 Jun 2011    Post subject: Reply with quote
do you think i would be better off getting a 70cc kit? as there the only one's i can find that are not chinese made
ill sort a few pictures out when i find out how to upload them
Nope.
PostPosted: 21:39 - 23 Jun 2011    Post subject: Reply with quote
Well, you can get a 70 kit but my friend with the 3 dodgy bore kits has fitted a 70 kit and its wrecked the bearings due to the high mileage engine (and the bearings already being shagged). So there is a risk.
Your choice.
chris vvc
PostPosted: 19:11 - 29 Jun 2011    Post subject: Reply with quote
Brought a new 50cc top end kit that came yesterday. The old man put the rings on the piston as he said hes done a few back in the 70's Rolling Eyes
Anyway he's got them on but they seem loose, are they meant to be gripping the groves tightly?
thanks
chris
The last post was made 15 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 127.51 Kb
