Renthal Bars - replacement grips
Ingah
PostPosted: 18:41 - 05 Jun 2011    Post subject: Renthal Bars - replacement grips Reply with quote
As i'm buying some service bits for my CB500 i've noted some new grips can be had cheaply to replace my worn-smooth-by-the-ages ones (and as i'm getting all the bits delivered it'd make sense to buy it all together to save on postage). Thing is i've just bought new Renthal universal handlebars and will be fitting them and i know that you have to use slim bar ends in them. Does this mean that standard grips won't fit either? (too loose)
Anyone with Renthals able to confirm / deny this, or recommend what i should be buying?
-- Ingah
potato
PostPosted: 19:38 - 05 Jun 2011    Post subject: Reply with quote
Normal grips should fit on renthals.
Just buy some new renthal grips for like £7 i think.
OOOooosshh!
PostPosted: 19:47 - 05 Jun 2011    Post subject: Reply with quote
Most handlebars are 7/8". If your lever clamps fitted, so should standard grips. They need narrower bar ends because they are made of thicker alloy tubing so the inside diameter is smaller to achieve a similar strength to steel ones.
Ranthall do also do bars in other diameters, they do fat bars (1") and taper bars, but if they are standard ones they'll be 7/8".
Ingah
PostPosted: 19:52 - 05 Jun 2011    Post subject: Reply with quote
Cheers Very Happy
-- Ingah
Slacker24seve...
PostPosted: 20:32 - 05 Jun 2011    Post subject: Reply with quote
If you get Renthal grips I recommend 'Medium', the hard ones I have are like sandpaper.... made of granite.
Banger rallies are ace
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.05 - MySQL Queries: 14 - Page Size: 43.61 Kb
