Electric start wont work
big lad
PostPosted: 21:08 - 23 Jun 2011    Post subject: Electric start wont work Reply with quote
Hello everyone, i bought a cheap yamaha ew50 in reasonable condition, just one or two problems,(ripped seat ect)
Anyway the electric start wont work, if i put power to the starter from the battery it will start, if i put power to the relay it will start, if i put power to one side off the starter switch it will start, but when i tested the voltage on the swithch there wasnt any power going to anything..and both wires going to the starter switch were earths...no live... i have checked all terminals all connected, nothing loose, tried moving the wiring loom to try and get a reaction but nothing...
Starter and relay are both fine..
starts fine on kick start, just would be nice if the electric start worked...
What should i do next?
Thanks for any help
SirEdward
PostPosted: 21:26 - 23 Jun 2011    Post subject: Reply with quote
Shocked
2 ground wires going to the ignition/starter button/switch? You'll need a wiring diagram, if that's a case - to find the live one going to/from the ECU or whatever ignition relay you may have on the bike.
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
finpos
PostPosted: 22:23 - 23 Jun 2011    Post subject: Reply with quote
In the absence of a wiring diagram...
You'll probably find that there's one real earth and the other is either simply disconnected by (although it may be earthed by) some sort of safety interlock (e.g. stand up, brakes on...) which you either don't know about or may be broken.
The other possibility is that there's a semi-functional immobiliser lurking in there.
f.
Stowelly
PostPosted: 22:27 - 23 Jun 2011    Post subject: Reply with quote
stupid question, but you tried the electric start with the clutch held in?
finpos
PostPosted: 22:33 - 23 Jun 2011    Post subject: Reply with quote
...Quick look at the Yamaha Aerox and Jog (hopefully similar) says you need a brake on to start.
f.
SirEdward
PostPosted: 21:12 - 24 Jun 2011    Post subject: Reply with quote
f.
Ding, ding, ding.
big lad
PostPosted: 21:21 - 24 Jun 2011    Post subject: Reply with quote
Give the man a medal, I'd almost stripped the bike back to a shell, b4 I red the brake post!! Thanks for the heads up...very much appreciated!!
Thanks
The last post was made 14 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 14 - Page Size: 51.57 Kb
