Exhaust Stud nuts
PostPosted: 22:18 - 28 Jun 2011    Post subject: Exhaust Stud nuts Reply with quote
Are these special in any way or can I just use Random stainless ones I have laying around?
Ta, Chris.
Bezzer
PostPosted: 22:32 - 28 Jun 2011    Post subject: Reply with quote
No reason you can't use them, I've made and used them for a few years on different bikes with no problem, it's not like they need to be HT on an exhaust. A2 is better than A4 for them.
sickpup
Old Timer
PostPosted: 01:41 - 29 Jun 2011    Post subject: Reply with quote
Use the brass ones that won't seize that you will no doubt pick up from me with washers in exchange for 2 cans of coke. Wink
8mm sir?
Frost
PostPosted: 02:47 - 29 Jun 2011    Post subject: Reply with quote
You can use whatever but ones with a flange will dug into the collars a lot less and are what should really be used.
When the old ones are off and the exhaust removed, do one up on to the thread then back off again a few times to help clean it out. A wire brushing might help too. then copper grease one of the new nuts and wind that on and off to make sure the whole thread is covered in the stuff and it'll never get stuck on. I did the above with a bike then removed the exhaust 3 years later and the nuts came off as easy as the day i put them on.
DrDonnyBrago
PostPosted: 08:24 - 29 Jun 2011    Post subject: Reply with quote
+1 to the brass nuts, even if they manage to corrode they strip before the stud snaps Thumbs Up .
PostPosted: 09:35 - 29 Jun 2011    Post subject: Reply with quote
8mm sir?
Ideal. Thumbs Up
The last post was made 15 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 14 - Page Size: 47.42 Kb
