 anthony_r6 World Chat Champion
 skatefreak World Chat Champion
 Posted: 06:59 - 06 Jul 2011 Post subject: |
unless theold chain has a split link:
https://www.dirtbikebitz.com/images/products/drive/renthal_link.jpg
then i would recomend cutting it off as you will have to get the swing arm off otherwise.
The new chain, again, unless its a swing arm you will need a chain tool (or a ball bearing and hammer ) to flair out the final rivet.
For bleeding, i use a 6 inch peice of pipe, pour brake fluid into the resivour, compress, open bleed bolt, close bleed bolt, release, repeate and jobs'a good'un.
Seems a little pricey just for bleeding the brakes...
Best regards
-Jvr |
