| Chalky. |
 Chalky. World Chat Champion
 Posted: 18:53 - 23 Aug 2011 Post subject: Undoing wheel nuts... |
Right, having some problems undoing wheel nuts.
They're on a 1960 tractor.
I've WD40'd, soaked all day, had blowtorch on them.
Using breaker bars with long scafolding pole on the end, snapped the head off 3 of the breakers.
Right, so I try welding.
Drilled a hole through a 10 foot long hollow tube, put a 6 inch extension bar through it. Welded inside and out of the tube with the bar running though it. Went to turn it, welds came loose like it was pritt stick.
Tomorrow I'm going to try drilling though the tube and bar the other way, pinning it, but has anyone else got any ideas/experience?
I don't really want to weld directly onto the nuts if I can help it...
Cheers. |
| N cee thirty |
 N cee thirty Banned
| The Artist |
 The Artist Super Spammer
| Chalky. |
 Posted: 19:17 - 23 Aug 2011 Post subject: |
Trying to locate someone with an impact gun.
I would not only like the nuts off in one piece, but also the wheels Mr Moss.  |
| N cee thirty |
 N cee thirty Banned
| The Artist |
| The Artist |
| Frost |
 Frost World Chat Champion
 Posted: 19:46 - 23 Aug 2011 Post subject: |
I've helped do this a few times on tractors. The last ones we did we had a breaker bar (non ratcheted socket driver) about a meter long with a scaffold pole 2 meters long with 2 big blokes on the end of it. It still didn't shift. In the end we did the above but first heated the nut up till it glowed cherry red, found a socket that fitted the now expanded nut and it came loose with a hell of a crack  |
| N cee thirty |
 N cee thirty Banned
 Posted: 19:50 - 23 Aug 2011 Post subject: |
https://i825.photobucket.com/albums/zz176/robyarr/DSC00748.jpg
just while we're all here,don't trust the artist  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| Chalky. |
| Chalky. |
| Chalky. |
| The Artist |
| N cee thirty |
 N cee thirty Banned
| Raffles |
 Raffles World Chat Champion
| Chalky. |
| Vincent |
 Vincent Banned
| Raffles |
| doggone |
 doggone World Chat Champion
| Chalky. |
| Chalky. |
| Chalky. |
| The Artist |
| Raffles |
| woll |
 woll World Chat Champion
 Posted: 22:26 - 23 Aug 2011 Post subject: |
Firstly a big dose of man the fuck up will help
Get a penetrating spray. NOT wd-40, it's a water dispersant with a slight amount of oil in it. Plus gas is good, soak them a few times with it.
Try hitting the nuts with a hammer, it can help break off rust in the threads.
I've had to remove wheel nuts off tractors recently that have been bastards normally that sorts them, 1m breaker bar with 2m of thick walled 1" dia pipe job done.
If not heat them up as somebody said till they start to glow.
I would offer to give a hand buts its a treck lol.
If it all fails give me the make & model of the beast (old nuffield isn't it?) and i'll get you a price for new wheel nuts and possibly studs from work (should be able to get them cheap 'cos im an employee) If we can't get them for that exact tractor fetch the studs of nuts with you and we'll find some to fit. ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
